Power beyond port for LA513 loader
/ Power beyond port for LA513 loader #1
Goattownwoodcutter
'06 KUBOTA L3130GST
I'm in the process of converting our loader to QA. Will a 3rd function valve kit work or need to get diverter kit?:)
/ Power beyond port for LA513 loader #4
Getting a grapple, need the 3rd function for it.
Ahhh... that makes better sense. I feel like I've chimed in on this subject three times in the past week. Apparently, tis the season for 3rd function valves. I just finished my install on my L3200. I went with the Landpride kit from Messicks. Many folks like their WRLong kits from EverythingAttachments. Someone else also chimed in with the kits from Summit, which can be had on Amazon or direct. Sounds like you have your answer though. I'm no expert, but as far as I can gather, 3rd function is ideal, Diverter will work, you just won't have the ability to use all functions at the same time. Maybe I need to make a video of my install????
/ Power beyond port for LA513 loader #5
Yes 3rd function will work off the power beyond port. If it is an electric over hydraulic valve for third function, make sure it can handle the full back pressure of the system down stream. Most can but should be verified. Good luck!
New Mini Skid Steer Grapple Bucket (A62679)
New Mini Skid...
2001 Peterbilt 330 4,000 Gallon Water Truck (A64194)
2001 Peterbilt 330...
Rake Master CR-50SG-LD (A64126)
Rake Master...
2021 Bobcat T770 (A64126)
2021 Bobcat T770...
KMC Strip Till Rig & Planters (A64126)
KMC Strip Till Rig...
2007 INTERNATIONAL PAYSTAR 5600 Bucket Truck (A62679)
2007 INTERNATIONAL...
