New Branson 2610H owner
/ New Branson 2610H owner #1
Moak
Greenfield Center
Massey Ferguson 3165 Bronson 2610H
My new 2610H got delivered last week and I only got a little time to look at things over and with the weather being in the single and teens its made it tuff since it just fits into my storage shed. I went out yesterday to remove my mid-mount mower so I can get things ready to use it for snow removal but I can not get the MMM to drop down with the 3 pt hitch lever am I missing something is there a lockout for the underarms I didn't see one all I see is the flow control knob for the speed of the 3 pt. If anybody has any insight it would be greatly appreciated.
If I don't figure it out by Tuesday I will reach out to my dealer
/ New Branson 2610H owner #2
I can not help you with the mower but would like to say congratulations and welcome to TBN and the Branson family! Post pictures when you can! :thumbsup:
K5iwq Thank you. We look forward to being part of the Branson family. I will get some pictures up soon I tried to put some with my profile but I couldn't get them to upload. I will try again later but here's one to know if this works.
Well it didn't work again I don't know why I can not get photos to upload I was able to change my Icon but I cannot get photos to upload.
/ New Branson 2610H owner #5
Hello and congratulations!
What is the MMM?
Did you try adjusting the flow control knob?
What is the MMM?
Thank you
MMM = Mid-Mount Mower
I did not turn the flow control know for it was set on fast and the 3point itself dropped right down
/ New Branson 2610H owner #7
I'm disappointed that the dealer didn't go over the tractor with you when they delivered it.
I'm sure one of the dealers that posts here regularly will be along soon to help you out.
Unfortunately, I don't have a MMM option on mine, so I can't help you.
/ New Branson 2610H owner #8
Are you trying to do this with an implement still on the 3 pt?
I was checking some of the pictures you posted on FB. And noticed the lift for the MMM consists on a rod coming back to the 3pt and 90 degree plate that sits on top of the lift arm.
If there is an implement on the 3 pt, the 3 pt arm won't go down enough and the MMM might no drop fully to the ground.
/ New Branson 2610H owner #9
I'm not familiar with the new mmm's and such but,
years ago when a front or mid mounted or side mount was lifted by the rear lift
many times there was a latch or safety clip to hold the implement in a locked up position.
There no Implement on the 3 pt. The MMM doesn't seem to move at all I even tried to bring the 3pt all the ways up and then lowering it and nothing. I don't know of any photos that I have on Facebook that show the MMM arms or linkages. What photo shows this I for some reason can not get photos to upload onto the forum. I'm going to go out now and see if I can see what you speaking of and I will take some photos of the underside of the tractor and I'll see if I can get photos of the back without having to start it and move it. To start it I would have to plug the block heater in I would think since its 8% here with the wind chill
Ok I went out and I see what you're talking about way down at the bottom of the lift arms they go around the arm and the arms ride on them they are losing I can move them and they're a lot of slaking in the rodes going through them to the mower. I wish I know why my photos won't upload I just took photos of it all
/ New Branson 2610H owner #12
You can either upload them direct to the website, or host them on a photo site and post the links.
There may be a certain post limit you have to make before TBN will allow you to post pictures.
/ New Branson 2610H owner #13
This is the picture I was talking about.
But after your last post, it might be just a lock or height adjustment being overlooked.
/ New Branson 2610H owner #14
To upload pictures click on the picture frame icon.
Then click on From Computer tab and click Choose File button.
Select your picture from where you have it saved and hit add button. Then you should see the thumbnail and then choose upload. This might take a moment so be patient.
Never mind you figured it out. Lol
I have done all that but the photo doesn't upload. I think I have it figuard it out by using the advance tab on the bottom
I went out and there are u plats that go over the lift arms and the same shaft for the arms go through them. I have to say these are what lift the mower and there got to be a lock somewhere to keep the mower up going by the slake in the rods going from those arm under to the mower linkage
142371473_190431999493699_6177337424740713287_n.jpg142404361_166892208223262_7761159426806730690_n.jpg142499886_849184259199707_1261634092121681782_n.jpg
I think you are correct I went back out and looked under the tractor at all the linages and took pictures and on both sides, there are what looks like U-tab but I can't get under there enough to see everything they are going through to see if something they go through is solid and I didn't want to pull them with the 3pt in totally down. I believe this u-tab is going though both of those arms so it cant lower
While I was on here and in the Branson owners FB group asking about this I did send my Dealer JC Tractors and Restoration a message and spit it being Sunday and being closed he did just get back to me and stated "" There is a pin that locks the mower in transport, up position. This needs to be released"" I also want to put a big thank you out to my dealer for tsking the time on a Sunday to get back to me and verifies I need to pull that pin so the deck can move
Here some photos of my 2610H
/ New Branson 2610H owner #20
Awesome. I had assumed it would be something easy to fix.
2017 Ford F-250 Ext. Cab Service Truck (A66736)
2017 Ford F-250...
2010 Chevrolet Camaro Coupe (A66738)
2010 Chevrolet...
COMBO PORTAPOTTY/TRASH TRAILER (A67714)
COMBO...
2021 Sany SMG 200C-8 Motor Grader (A62679)
2021 Sany SMG...
2020 FREIGHTLINER M2 106 WATER TRUCK (A67714)
2020 FREIGHTLINER...
2018 MACK CXU (PINNACLE) (A67714)
2018 MACK CXU...
