JD 4600 Yanmar 4TNE84 engine rebuild problem - Crankshaft balancer
/ JD 4600 Yanmar 4TNE84 engine rebuild problem - Crankshaft balancer #1
desmetde
My John Deere 4600 tractor (2000) equipped wit a Yanmar 4TNE84 engine threw a connecting rod. I ordered a 4TNE84 short block to swap out. During the engine disassembly I find something very interesting that I cant seem to get an answer on.
The original engine has a crankshaft balancing unit that sits above the oil pan, driven by a gear on the crankshaft. The short block I bought doesnt have this gear on the crankshaft. It appears the oil passages are modified as well.
Did Yanmar change to a harmonic external balancer?
Can I still use this short block without the internal balancer?
has anyone seen this?
Thank you, Dan
/ JD 4600 Yanmar 4TNE84 engine rebuild problem - Crankshaft balancer #2
In 4cyl automobile engines the internal gear drive balancers are used to cancel out second order harmonics and are geared to 2x engine speed. Sole purpose is to reduce the vibration felt by passengers. Not required for crankshaft torsional harmonics. The engine still has a classic harmonic balancer for torsional vibration. Not sure why a tractor diesel engine would have this type balancer. Must be a Cadillac ride.....
Thank you, Dan
See the attached photos, with labels
J Thibodeau, thank you for your reply. i attached some pics below, so your opinion is that I dont need his balancer?
I wish I could find a John Deere dealership that even knew what I was talking about.
why would one engine have it and another not? when they are the same engine model?
Dan
/ JD 4600 Yanmar 4TNE84 engine rebuild problem - Crankshaft balancer #5
JD begin utilizing engine balancer box 60 yrs ago on model 3010(see photo). Then in '65 the engine utilized in the utility tractors with 4 cylinder engines had balancer shafts. Some of these same utilty 4 cylinder engine utilized in other applications had no balancer shafts.
this engine is a 2000 year model, do you think im safe to use the short block without the balancer unit?
/ JD 4600 Yanmar 4TNE84 engine rebuild problem - Crankshaft balancer #7
Maybe the replacement engine was for a generator or another application where vibs don't matter? A letter or number at the end of the model might mean anti-vib or not.
/ JD 4600 Yanmar 4TNE84 engine rebuild problem - Crankshaft balancer #8
There is a model 4TNE84 AF, EAF, GB2B, and maybe others. This site listed parts and the crank was not to be used on balancer engines. (note 3 at bottom)
Yanmar 4TNE84 | Maxiforce
/ JD 4600 Yanmar 4TNE84 engine rebuild problem - Crankshaft balancer #9
Dan
Those pics look just like the balancer we put in the 4cyl auto engines. The engine without balancer will definitely shake more. This type of crank driven balancer is the only way to get rid of 2nd order vibration. The gear must be phased correctly with the crank when installed. The crank couterweights and spin balance (1sr order) are the same.
Mechanically the replacement engine will run just ginr without the gear driven balancer. But you eill feel mpre vibrstion. Does the replacement block have all of the required mounting holes?
Thank you once again, not sure about the mounting holes yet, so far looks exact
/ JD 4600 Yanmar 4TNE84 engine rebuild problem - Crankshaft balancer #11
Just curious, did the short block come from a deere dealer? The part number for the short block substitutes a couple of times. but no notes on elimination of balancer. John Deere part number for short block is MIA882698.
it did not come from John Deere, I ordered it from Ebay.....China
maybe not a great idea, but..... you can see the different numbers on the two block in the attached pictures
It cost me $2100 when a John Deere Short Block Assembly Part Number: MIA882698 Price: $11,401.97
Thank you for your reply
Dan
Thank you Tx Jim!
/ JD 4600 Yanmar 4TNE84 engine rebuild problem - Crankshaft balancer #14
You're welcome.
/ JD 4600 Yanmar 4TNE84 engine rebuild problem - Crankshaft balancer #15
I would say go ahead and use it if you dont mind having some vibrations.
/ JD 4600 Yanmar 4TNE84 engine rebuild problem - Crankshaft balancer #16
New to the forum, so I thought I would do a little reading and if I can help anyone, so here is my 2 cents. You might try finding the right person at a yanmar industrial engine sales firm. As far as I know they are pretty tight with their distribution in the states, and the companies that are listed as distributors are usually trained. I know of a company called Ultraquip in San Antonio that I believe is a yanmar dealer. Might give them a call and see if someone could shed some light on the issue.
/ JD 4600 Yanmar 4TNE84 engine rebuild problem - Crankshaft balancer #17
Thank you, Dan
just installed 2 of these engines in JD4600 tractors. you have the wrong engine. you can contact Wayne @crosspoint 317 618 1057 Indianapolis In. you will have to have complete engine sn. He will work with you Thanks Billy
Dan
Ive got the engine installed and the tractor up and running. working out the kinks with it now. she runs great except for a random stall. Cant figure it out yet, seems like intermittent stalling, when in fwd or reverse, I can hear the fuel solenoid click, sometimes clicks multiple times in a row, and the tractor stalls , most of the time I can throttle up, or take it out of fwd/reverse (power reverser) into neutral and i can keep it from stalling, but other times it just stalls, but fires right back up. Ive been trying to duplicate the stalling while running in neutral, ill go around and move wire connectors, but havent found the culprit yet. I replace the fuel solenoid and it didnt improve. Dont know if its a safety circuit wiring/switch issue, or a fuel delivery issue. but the solenoid is definitly clicking as it occurs....any suggestions?
Dan
/ JD 4600 Yanmar 4TNE84 engine rebuild problem - Crankshaft balancer #20
Probably a safety switch.
Do you still have your seat presence safety? That one kills the engine. The others keep you from starting, IIRC.
As for the interesting problem with the balance shafts, I suspect not only the crankshaft does not swap with the non-shaft version, possibly the pistons don't either. I have rebuilt 4 of the 3-cyl versions of this engine (3TNE84), and the pistons have steel weights cast into their undersides. No balance shafts.
PALLET OF MISC CHANNEL IRON (A62130)
PALLET OF MISC...
UNUSED KJ 11'X19' ALL-STEEL CARPORT (A62131)
UNUSED KJ 11'X19'...
BUYERS PREMIUM & PAYMENT TERMS (A59908)
BUYERS PREMIUM &...
2018 22ft. Tycorp Vector Belt VB-16H (A60352)
2018 22ft. Tycorp...
UNUSED WOLVERINE PFF3-13-45W UNIVERSAL MAST (A62131)
UNUSED WOLVERINE...
UNUSED 2026 INDUSTRIAS AMERICA 7014 7'X14' DUMP TR (A62130)
UNUSED 2026...
