Good morning!!!!
   / Good morning!!!! #126,161
Lou, did you ever try siping your tires for snow work? You must get more snow than any of us.
No need to sipe with chains, and likely nothing works better than chains, including going into the woods.
Chains sure will scratch up pavement though. Are your farm roads gravel?
turf, hybrid, R4, R1 lot of options, wonder which works the best? Probably tracks...but not including them,
if you wanted the best possible snow traction, which tire would you choose? Probably well discussed in the Transportation
threads... We need a comparison test; I've seen the ones on dirt/turf but not snow.
I have had sipped tires on a couple of pickups they did work better but not as good as studded tires.
As far as chains I went with the studded Euro style several years back and there is no comparison,
they re a 10 fold increase in traction and have a very good ride quality. I don't see any pavement damage to speak off
from my chains or the tractors when they are chained up at the farm. With the Euro style the traction is good enough
that you are seldom spinning and chewing with them which is when they would mark up the pavement.
All of our driveways and farm roads are gravel, most of the town roads are paved now that we drive on.
When I take my tractor over to the farm it's on pavement for about 3 and 1/2 miles each way. The feed lot tractors
run almost 2 miles on pavement daily when chained for the feed lot fields. The Euro style seem to hold up to the road travel
better then ladder chains as well as riding good, we will run about 15 mph with chains on.
My self I have to have chains on my snow removal equipment because of the steepness of my driveway, 14-16 degrees of
slope (about 25%) it's easy to plow down without them but difficult to get back up without them.
In my opinion the best snow tires for tractors would likely be the hybrid or the turf patterns, I'm running R1's as they are not worn out.
My backup tractor is on almost worn out R1's but with the chains is doesn't matter.
I have never been impressed with tracks for snow and ice work on equipment, without ice caulks they are about like ice skates.
   / Good morning!!!! #126,162
studded Euro style
Good to know
I used to scratch up the main road a bit when I plowed as a kid, could only see it when everything melted.
Seems like a lot of passenger/truck tire technology for snow tires could apply to tractors also.
Probably already does, like in radial tractor tires.
I think pressuring down our tractor tires in winter a few pounds might help too.
And always run 4wd if you can if there's any slippery stuff on the ground/roads.
Not just for pulling grip but for stopping. Learned that here.
   / Good morning!!!! #126,163
BIL, a teacher, has been sick two weeks with covid symptoms, but test are negative.
Buckeye hope you were not exposed.
They were still giving out vaccinations all day at our hub. FamilyHospitalSystems had 3 hubs in the county and gave out 6000 doses in three days. At our hub the police were standing by outside and you could only get in by appointment.
Rick is that at the Methodist Hospital in TMC, I saw they got a large shipment delivered.
Hays County, 2 counties away, received 2,000 doses today and open up the portal to sign up at 1:30 p.m., within 15 minutes all appointment slots were full.
In about 3 weeks half of the doses will go for the booster and the availability will be cut in half. I did read that in extreme cases CDC allows either vaccine to be used and given within 28 days to 6 weeks of the original vaccine.
"Rick is that at the Methodist Hospital in TMC, I saw they got a large shipment delivered."
Patricia's vaccination will be at Memorial Herman.
   / Good morning!!!! #126,164
Best tire I've used on snow were turfs...good tread pattern. Probably not good on ice though.
Nokian makes a snow tire for tractors...and Deere actually has a model (IIRC, it's a modified 4066R) designed for plowing snow that comes with Nokian snow tires. A very expensive option though
   / Good morning!!!! #126,165
After my dad was sent home yesterday in the COVID shot debacle, my sister was notified later they still had shots available so my dad was able to get his first shot.
   / Good morning!!!! #126,167
studded Euro style
I’ve run 4WD/AWD on trucks, cars and tractors for over 40 years, I’ve never seen any difference in stopping ability, if anything it got me over confident when I was young.
   / Good morning!!!! #126,168
Good morning! All of 1 degree warmer than raw this morning, it is 16. The advantage of living further south. :laughing: Allegedly going to 28 today. Sunday night thru Tuesday still looks to be a mess.
RNG - for my temporary shore power, used something similar to this:
https://www.amazon.com/Integrated-Extension-Flanged-Compatible-Waterproof/dp/B08CV1SM7H
I had one in my old trailer along with a power strip with a 15A breaker. Very basic shore power for a trailer or van. I am still deciding on whether this will go thru the wall as a permanent shore power or go 30A inlet. For the temporary inlet, removed one of the D-rings from the floor, made a cover for the hole, and installed the power inlet into the cover. Then bolted the assembly to the floor. Add a power strip with a breaker, and I have power in the trailer so I can work inside, charge the battery for the lights (12V), etc.
My dad and stepmom are getting their vaccinations this morning.
Getting some free firewood this afternoon. That is good since I didn稚 get all of my wood split before I got sick. The crappy HF trailer has a full load (okay, overload) sitting on it needing split. At least I covered it with a tarp. Crappy HF trailer is actually a compliment, I have abused that trailer since I bought it about 8 years ago for $100.
Not sure what else I will get into today......
Everyone stay safe out there.
   / Good morning!!!! #126,169
Glad your father got his shot BEF
Now have two employees with COVID one drives truck other works on ground
Prayers for all
Prayers for our Country
Try being nice to someone today treat others as you would want to be treated and respect try it it might surprise you
   / Good morning!!!! #126,170
I致e run 4WD/AWD on trucks, cars and tractors for over 40 years, I致e never seen any difference in stopping ability, if anything it got me over confident when I was young.
I ran 2WD for years on most things. That 兎ventually taught me to slow down. Took a while, but I did learn. :laughing:
My last 3 trucks have been 4WD. By driving sensibly in snow and ice, I can tell a definite difference in braking with 4WD versus 2WD. The 4WD is much more predictable to me when braking.
And without question, make getting up some of the hills around here possible in poor traction conditions.
2019 CATERPILLAR 259D SKID STEER (A52705)
2019 CATERPILLAR...
Giyi Excavator Attachment Set (A57149)
Giyi Excavator...
2016 Komatsu PC360-11 Hydraulic Excavator, S/N A35687, PIN# KMTPC256CGWA35687, Turbo Diesel Engine, (A59076)
2016 Komatsu...
John Deere 555 Track Loader (Rebuilt) (A59213)
John Deere 555...
New/Unused CFG Industrial H15R Mini Excavator (A57453)
New/Unused CFG...
KUBOTA SVL75 ENCLOSED CAB (A52706)
KUBOTA SVL75...
