oil leak
/ oil leak #1
gpbuz1
lexington, Indiana
1977 ym240
my little tractor has developed a leak around the steering shaft coming out of steering box! seems to be a seal there but i could not locate it in the service manual, any help would be appreciated. Thanks in advance
/ oil leak #2
SEAL - HORIZONTAL SHAFT IN STEERING BOX: Yanmar Tractor Parts 2021-01-23-062454_3.jpg2021-01-23-062454.jpg2021-01-23-062454_2.jpg
#21, Hoye has video's on repair if needed. How-to Video Section
/ oil leak #3
It's good to have the Parts Manual to see how parts are arranged in the diagrams. The images Winston shared are from the Parts Manual.
See attached for the YM195/YM240 machines.
Compliments of the Yanmar Tractor Owners Group on GroupsIO.
  • YANMAR YM195 YM240 PARTS MANUAL 000Y00T2381.pdf
  • YANMAR YM240 Hydraulic Service Manual YT7707-165E.pdf
  • YANMAR YM135 YM155 YM240 YM330 ELECTRICAL MANUAL.pdf
  • YANMAR YM195 YM240 YM330 SUPP SERVICE MANUAL.pdf
  • YANMAR YM195 YM240 OPERATION MANUAL 41812-011200.pdf
/ oil leak #5
A leaky steering box was so common on older Yanmars that the factory sent out a service bulletin asking dealers to tell customers to be sure to cover the steering wheel to prevent water from getting in. The interim fix was to place another decal over the center of the steering wheel to keep water out of the locking nut! There should also be a factory weep hole on the back of the tubular steering wheel shaft just above where the shaft enters the steering box.
If yours is leaking oil out that weep hole, it's because the box itself is full of water. Expect to replace several bearings and seals - they are all inexpensive.
rScotty
/ oil leak #6
rScotty
From the rScotty archive, see attached.
