Who has installed Bolt On Hooks to their LA1065 bucket
/ Who has installed Bolt On Hooks to their LA1065 bucket #1
TxMN
North Central Texas
2020 Kubota MX5400 HST, ROPS, 2020 Kubota RTV 900, 2020 Kubota RTV 500(wifeç—´ ride),
Did you use Bolt On Hooks standard hook and clevis for your 1065? I have the round back standard bucket. Would like to have hook with clevis on corners and one of each in middle of bucket edge. Anyone have a different set up they like?
/ Who has installed Bolt On Hooks to their LA1065 bucket #2
The LA1065 is the loader, not the bucket. Your bucket should be the L2236 or L2296, I believe both of those are rounded.
Can’t help with hooks but I would probably keep them located between the arms just to reduce torque when lifting, probably wouldn’t make a difference it’s just what I would do for my feelz. The center one would probably get used the most for me. I use a EA grapple about 85% of the time and forks about 14% of the time so the 1% when I use the bucket it’s usually doing bucket tasks so I just haven’t justified adding hooks. But all that to say when I hook up a chain or strap it’s usually one point of lift and it’s usually in the center or over frame of the forks.
/ Who has installed Bolt On Hooks to their LA1065 bucket #3
I put bolt on hooks on my LA 1153 bucket. Down on the corner - each side. Made a bridle - goes hook to hook. For when I want to pull from the center. I haven't used the bucket since the grapple went on the FEL seven years ago. View attachment 683597
/ Who has installed Bolt On Hooks to their LA1065 bucket #4
Time was, I used my bucket to move my large Ponderosa pine log chunks. Each side - use the hooks and two short sections of chain to get the log attached and to keep the log firmly in the bucket. The grapple is so much easier.
Correction, my bucket is a L2235. I don’t have it at my home location, and I have no photos that clearly show the top bar of the bucket where the hooks install.
I also have 48 inch forks and land Pride grapple, so it sounds like either of those may eliminate most needs for hooks??
/ Who has installed Bolt On Hooks to their LA1065 bucket #6
Peter 315, I like that attachment method, simple and sturdy. Thanks
/ Who has installed Bolt On Hooks to their LA1065 bucket #8
/ Who has installed Bolt On Hooks to their LA1065 bucket #9
/ Who has installed Bolt On Hooks to their LA1065 bucket #10
I prefer my method but I don't have a grapple to deal with.
This way I can run the chain down the front of the bucket or the back. And I have a place to hang extra chain so it isn't getting caught up in things.
Ken, i viewed your photos of Kubota products, but none of the photos Identify The buckets by model/ part number and I don’t have a good enough photo of my bucket to compare.
/ Who has installed Bolt On Hooks to their LA1065 bucket #13
IMG_0591.JPG B26 HD bucket.
Use the receiver hitch more for
attachments than trailer hitches. Bale spear, barbed wire unroller, vise, platform for sprayer, etc.
/ Who has installed Bolt On Hooks to their LA1065 bucket #14
I went this route so I can grab something from either side but have it slip/lift from the middle to keep the load balanced
Peter, where did you find the oblong ring with hook?
/ Who has installed Bolt On Hooks to their LA1065 bucket #17
R and R a junk store in Hooksett Nh. I got a set and mailed them to another member on TBN was around 20.00 Pm me If you want a set...
/ Who has installed Bolt On Hooks to their LA1065 bucket #20
HIGH END MINI GOLF CART (A58214)
HIGH END MINI GOLF...
2021 New Holland Powerstar 110 (A60462)
2021 New Holland...
Iranch IRGC40 (A60463)
Mini Ex Rake Attachment (A60463)
Mini Ex Rake...
2016 PETERBILT 389 FLATTOP (A60736)
2016 PETERBILT 389...
2005 Peterbilt 387 with Wet Kit (A61307)
2005 Peterbilt 387...
