Quick Attach Adapter Max 28
/ Quick Attach Adapter Max 28 #1
mitchash
Gold Member
Greene, NY
Mahindra MAX 28XL, Jinma 254 (Sold)
Im looking for a quick attach adapter for my Max 28XL. I would keep my bucket pin on and use the adapter plate for a set of forks I have, also might get a snowplow. I have found a couple of universal ones. Anyone have any experience and recommendations? Thanks
/ Quick Attach Adapter Max 28 #3
You will have very weak curl force with a QA on the Max.
Does the newer Max26 have the quick attach? Can that be adapted to the Max28?
/ Quick Attach Adapter Max 28 #5
I am unsure if it can (however if you - just weld the original bucket tabs directly on to the adapter plate) you will not lose much of your bucket breakout force).
He is right that some breakout force it lost... but.... I upgraded my hydraulic bucket cylinders. Thanks To a fellow on here
The Modification that I made moved the bucket away from the pins buy only 1". I 'had' to have pallet forks installed.....as my son uses it frequently for Pallet handling
Where did you get the upgraded bucket cylinders? Mine seem weak even with the stock set up.
Thanks
/ Quick Attach Adapter Max 28 #7
The bucket cylinders were replaced with larger ones. Here is a link from the original Poster who came up with the idea! Good People!
Weak Loader Curl Possible Solution For the Max28
Just remember that this required cylinder modification... and parts must be "made" to ensure proper fitment.
2013 Chevrolet Express Cargo Van (A64556)
2013 Chevrolet...
2023 New Holland C327 High Flow Compact Track Loader Skid Steer (A64553)
2023 New Holland...
2025 SDLANCH IRGC40 Two-Seat Electric Tricycle (A64194)
2025 SDLANCH...
213101 (A64276)
213101 (A64276)
2014 Kenworth T370 21ft. Flatbed Truck (A64194)
2014 Kenworth T370...
2009 FORD F-750 XL SUPER DUTY DUMP TRUCK (A63276)
2009 FORD F-750 XL...
