1026R Mid PTO Oil Seal
   / 1026R Mid PTO Oil Seal #1
Spanner
Auckland, NZ
John Deere
Whoops
Did those pictures show up?
I'm working on the phone, through the App and can't see my pic's.
   / 1026R Mid PTO Oil Seal #5
Yes the picts are definitely there.
What's up?
Apologies for the delay. I've upgraded my laptop and yes, the pic's are there. They are of the oil seal for the Mid-PTO on a 1026R (And other models.)
My query was related to the installation of this oil seal which has a metal outer shield integral with the seal itself.
I hadn't seen this type of seal previously.
When looking at the Parts Diagram it originally (last year) showed the seal as being installed from inside the transmission.(The dotted-line style of 'directions')
I asked the dealer whether this was correct or could the seal be replaced from the outside without splitting the trans. ?
The dealer told me it was inserted from the inside, so yes, split the trans. They gave me a 4-figure quote to do this work.
That 'bothered' me a bit as I didn't think JD would be so awkward about a seal but hey, who knows?
I waited over christmas and attempted to ask on here hence the OP.
Then I rechecked the Parts Diagram to be sure of my facts and it has since been redrawn to show the seal inserted from outside the trans.
So I drilled into the seal shield, inserted the two self-tappers and levered the old seal out.
Phew!
Then I installed the new seal. All good.
That's all. That's what the initial post was to be about.
I used to work for this dealer. The tractor wasn't in production when I left.
Hence I had no knowledge of the replacement procedure or access to the Service Advisor tech manual.
(The erroneous advice to split the trans is consistant with why I left there to work for myself. )
Thanks for your patience.
2016 ISUZU NPRXD 14' BOX TRUCK (A60430)
2016 ISUZU NPRXD...
2003 MACK 1M2 DUMP TRUCK (A60430)
2003 MACK 1M2 DUMP...
Unused 2025 CFG Industrial QK16R Mini Excavator (A59228)
Unused 2025 CFG...
2017 Ford Transit 350 Passenger Van (A59230)
2017 Ford Transit...
New Holland WorkMaster 37 (A53317)
New Holland...
1998 MACK DUMP TRUCK (A60430)
1998 MACK DUMP...
