FEL backhoe attachment
/ FEL backhoe attachment #1
HawkinsHollow
SE TN
Branson 3015R
These backhoe attachments are being sold locally online for $800. I understand one would have to be EXTRA careful using something like this on an FEL. They are being sold as a skidsteer attachment, but would work on a CUT FEL. How useful do you think something like this could be IF ONE WAS EXTREMELY CAREFUL? $800 is pretty reasonable for backhoe like capabilities. My gut tells me it's not a great idea. But I just wanted to see what y'all thought.
/ FEL backhoe attachment #2
Maybe a little better than a shovel for planting a tree or something but not very useful.
/ FEL backhoe attachment #3
/ FEL backhoe attachment #4
The problem either way is repositioning the arm to empty the bucket. Excavators and backhoe's articulate from 160° to 360° to help process the work. Every scoop on this would require moving the entire machine which makes it terribly inefficient and potentially could tear up the ground even more due to tire/track traffic
/ FEL backhoe attachment #5
^ eh, you wouldn't really need to move the tractor for every scoop. Could work straight backwards until you have a pretty big pile, then turn around and use a box or rear grader blade to shove the pile out of the way.
I dunno, if you had nice sandy soil, with minimal huge tree roots, and no random boulders, this would work very well for trenching (since it goes so much deeper than a bucket spade). Pretty dangerous for stumping or boulder picking though, in terms of loader safety.
/ FEL backhoe attachment #7
If designed and intended for a skid steer, my first question would be the required hydraulic flow requirements.
It is not unusual for a skid steer to push 50 gallons per minute flow rate or greater and our compact tractors to push less than 10 gallons per minute.
If this is the case with this attachment, on a CUT tractor you may not be able to dig in much beyond loose sand.
/ FEL backhoe attachment #8
A skid steer isn’t pushing anything close to that much in a hydraulic cylinder implement like a grapple or backhoe attachment. I won’t deny that it probably won’t dig much more than loose sand but lack of hydraulic flow won’t be the problem.
2012 FOREST RIVER 24' T/A ENCLOSED TRAILER (A65643)
2012 FOREST RIVER...
Land Pride 3Pt Mower (A66408)
Land Pride 3Pt...
New/Unused 3 Point Receiver Hitch (A65583)
New/Unused 3 Point...
Iranch High-End Tricycle (A64119)
Iranch High-End...
2021 DITCH WITCH HX30G VACUUM TRAILER (A63276)
2021 DITCH WITCH...
PORTER CABLE AIR COMPRESSOR (A65643)
PORTER CABLE AIR...
