pole saws at work (photos)
   / pole saws at work (photos)
More trail clearing photos taken today.
   / pole saws at work (photos) #82
Over the last couple of days I cleaned off about 900 feet of trees, limbs, multi floral roses and bushes that had grown over a section of my pasture fence. Using the Echo PAS with the pole saw and brush cutter attachments sure made the work easier than just using a chainsaw. I have about 400 feet to go then the clean up begins. There's going to be a mountain of brush to move.
Here's a pic of part of the work.
Thanks for posting photos of your handy pole saw work Houser. We need more photos! I could critique your cuts. Do you want me to?? :confused:
   / pole saws at work (photos) #84
Sure. Critique away.
You are suppose to cut all branches at the tree trunk, whenever possible... Its better for the tree, and for cosmetics.
   / pole saws at work (photos) #86
Thanks for the info. I try to do that whenever it's safe and I can reach up next to the tree to make the cut. Some of those limbs were so big, long and hanging down I could only reach so far.
   / pole saws at work (photos) #87
I hate multiflora rise with a passion. It’s about like covering yourself in tuna and being attacked by a dozen Hungary cats.
   / pole saws at work (photos) #88
They are wicked! That's where the pole saw is worth it's weight. You can reach in to make a cut without tearing the skin off your arms.
   / pole saws at work (photos) #89
houser.............I think that I see a grapple in your future............:D
   / pole saws at work (photos) #90
Yep. Got that covered already. A grapple used along with a landscape rake should make the work bearable.
IRGC80 Lifted Electric Golf Cart **Unassembled**(New/Unused) Plugs into standard 110 outlet , Com... (A59225)
IRGC80 Lifted...
2010 Ford Fusion Sedan (A56859)
2010 Ford Fusion...
2012 DRAGON PRODUCTS CRUDE TRAILER (A58214)
2012 DRAGON...
2016 FREIGHTLINER CASCADIA (A58214)
2016 FREIGHTLINER...
STAINLESS STEEL GRATES (A58374)
STAINLESS STEEL...
2018 ALLMAND MAXI-POWER 45 GENERATOR (A58216)
2018 ALLMAND...
