kuboto snow blower
/ kuboto snow blower #1
tommygun
Member
2010 kubota 2620
is it wise to increase snow blower fan to increase distance it will blow snow?
/ kuboto snow blower #2
Short answer: No. It depends on the snow's relative water density as well.
/ kuboto snow blower #3
Depends on what you mean by increased snow blower fan. I run my 63-in snowblower at the rated rpm, 2500. Are you referring to fan speed?
/ kuboto snow blower #4
In my experience I have found that I would shear less bolts running at higher rpms.
/ kuboto snow blower #5
My blower is a 'not so great' version.
OK, price was great. ($400)
I have improved it by lining the chute with plastic, (no stick) and since my CUT has 3 speeds on PTO I use the middle one, 700 +/- RPM.
Next I developed techniques to make my 'blowing experience' workable.
OK, more fan blades= better,
Larger fan diameter= better,
BUT that all wants HP at the PTO, Do U have what it takes?
Then, private (like I'm not in a real hurry) or commercial (time is money) situation.
Hey, with time, patience (and or money) that snow will be gone!
Maybe by next summer, LOL.
yes I a talking fan speed. I run the tractor at 3000 rpm and the PTO at 960
Thanks for the replys
/ kuboto snow blower #8
yes your theory is correct
2017 TAKEUCHI TL8 SKID STEER (A65056)
2017 TAKEUCHI TL8...
2018 MACK LR633 6X4 T/A SIDE LOAD GARBAGE TRUCK (A66091)
2018 MACK LR633...
2012 KENWORTH TRIAXLE BODY LOAD (A67714)
2012 KENWORTH...
HYDRAULIC FLUID TANK (A67714)
HYDRAULIC FLUID...
11R24.5 Tires - Set of 4 (A68134)
11R24.5 Tires -...
2006 PETERBILT 379 (INOPERABLE) (A67714)
2006 PETERBILT 379...
