Traction 4wd
Rbarry419
Mahimdra emax 22
Any suggestions my emax22 4wd will not engage due to 4wd and hi low levers being stuck together
Is it normal for the levers to be stuck together on this model? If not you should consider investigating why yours are hung up. Your dealer may be able to offer some suggestions.
/ 4wd
Not normal should move freely
What I did on mine when they were sticking like that was to lube the ends. Down by the shaft coming out of the transmission.
/ 4wd
I’ll try that and see what happens thanks
Sounds good! Let us know if it helps the situation!
/ 4wd
Soaked it with fluid film let everyone know what happens
/ 4wd
Sprayed all connections let sit 24hrs no luck
FF wont work .... Try Kano Kroil Penetrating Oil or some other rust busting penetrating spray.....
/ 4wd
Picked some up today and got some ideas from dealer, going to try a few things and get back to the feed.
/ 4wd
No luck going to have to take it apart, dealer can sell me a new lever with plastic cylinder so it doesn’t happen again 75.00
Sorry it didn’t help you! Please let us know what you find out. And pics or it didn’t happen...
2014 DODGE RAM HEAVY DUTY INSULATED BUCKET TRUCK (A63276)
2014 DODGE RAM...
2016 Ford Transit 350 Wagon Passenger Van (A64556)
2016 Ford Transit...
Smalline 4in. Double Diaphragm S/A Towable Trash Pump (A64553)
Smalline 4in...
2022 EZ-GO ELITE...
2024 MACK GRANITE GR64F DUMP TRUCK (A63276)
2024 MACK GRANITE...
2014 MERCEDES 2500 CARGO VAN (A67147)
2014 MERCEDES 2500...
