Antifreeze Leak Unknown Location
/ Antifreeze Leak Unknown Location #1
Bladerunner6
Elizabeth City, NC
John Deere 950, and John Deere 5065E w/553 Loader, John Deere Gator XUV 825M
I have a 2019 John Deere Gator XUV825MS4.
This morning was out doing morning chores I heard some gurgling noise under the hood, but didn't think too much of it at the time. The engine temperate light never came on, so finished chores and parked it in the barn. Came back a couple of hours later pulled the gator out for another run to check fences and on returning noticed a pool of liquid on the barn floor. It looked like coolant had leaked from somewhere around the recovery tank/reservoir. The liquid in the reservoir was boiling when I returned to the barn. I let it cool down and by that time the tank itself was empty. We removed the tank filled it with water, but didn't see a leak.
I removed the radiator cap once it had cooled and could see that the coolant level was a little low, but not by much. I could still see it in the radiator. There doesn't seem to be any leaking around any of the hose connections or the hoses themselves.
I am at a loss here. Anyone have any ideas?
I don't think it would be under warranty, even though I bought an extended warranty on the Gator. I may just put it all back together and haul it down to the dealer.
/ Antifreeze Leak Unknown Location #2
Ideas? Yea but I think your idea of hauling it to the dealer is as good as any.
/ Antifreeze Leak Unknown Location #3
I have had weird situations with a bunch of differnent equipment and vehicles. See (obvious) drips of coolant in the snow and NEVER find the source, nor does anything ever later reveal itself.
/ Antifreeze Leak Unknown Location #4
If there was a puddle, as least you could get a good idea where it came from, provided you didn't move the machine. I only ever see yellow marks in the snow.
/ Antifreeze Leak Unknown Location #5
If you have warranty, see if the dealer will work on it for no charge.
If he won't, you can pick up a product at most auto parts stores that's a dye that you put into the cooling system. Clean the machine as well as you can. Add the dye to the radiator. Run the machine until it gets hot/starts overheating, etc... Then you check the machine in a dark garage or at night with a black light (usually included in the kit) and the dye will fluoresce under the black light, showing you where the leak is.
I've used it a number of times on car and truck cooling systems. They also make one for the oil system. Both work great! :thumbsup:
/ Antifreeze Leak Unknown Location #7
AHhh but there was a time when your name in snow was possible,now days initials are a challange.
/ Antifreeze Leak Unknown Location #9
It's the stuff in them thar Chem Trails. Makes things shrivel up so they don't reproduce.
/ Antifreeze Leak Unknown Location #10
The gurgling sounds like running hot, say from low coolant, circulation restrictions, radiator blockage, etc.
There may be a temp-controlled fan/switch that's not functioning, esp if it's a convection vs pump-driven system.
If gurgling when parked hot there may have been enough steam expansion to overflow the reservoir as said in post #4.
Thank you for all the responses. I contacted the dealer and am waiting on him to find out if its still covered under warranty. I have an extended 60 month warranty, so think it will be covered. I pulled out the original paperwork when I bought the Gator and was happy to see where I had paid $1400 for the 5 year warranty.
The service manager at John Deere thinks its most likely the thermostat or worst case a blown head gasket. I will post once the problem is figured out.
/ Antifreeze Leak Unknown Location #12
When I first got my new M6040 I added antifreeze to the overflow tank. It looked a "tad" low. I later learned it was just fine the way it was. I was horrified when I saw a small pool of antifreeze on the ground. I traced it back to the overflow tank. It was discharge from the tank overfill hose. Became abundantly obvious - tank was full to the bloody top - antifreeze still present in the overfill hose. What a relief .........
/ Antifreeze Leak Unknown Location #13
I am wondering if there was a way to pressure test. I would check and resnug up the radiator hose clamps.
I had an X740 JD that loses tank antifreeze until it is almost empty but the rad. is always to the top. I just keep an eye on it.
/ Antifreeze Leak Unknown Location #14
Let the extended warranty pay for the fix.
I am thinking head gasket, water pump or belt, thermostat, or cooling fan/fan switch failed.
UPDATE when you know!
/ Antifreeze Leak Unknown Location #15
O/flow tank should be near empty when cold, near full when warm. Easy cheap pressure/integrity test is to look at the level in it. If it stays full when cold there's a leak drawing air in. If its never the same as op temps vary the system is tight.
Pressure test by plumbing to o/flow tube at filler neck and teeing in a gauge. Use a dummy cap with the small rubber ring removed. Do NOT apply more than 15 PSI if you can help it. Radiators may be tested to 30 PSI, but some won't handle 20 after so many years. A proper cap will pop off at 15. :2cents:
2006 KENWORTH T800 TRIAXLE (INOPERABLE) (A67714)
2006 KENWORTH T800...
2018 MACK LR633 6X4 T/A GARBAGE TRUCK (A66091)
2018 MACK LR633...
2014 CHEVROLET CAPRICE POLICE CAR (A66091)
2014 CHEVROLET...
WORKBENCH WITH VICE (A68842)
WORKBENCH WITH...
2015 WINSTON AP22024AL-DC T/A 24FT TRAILER (A66091)
2015 WINSTON...
2017 KOMATSU HM400-5 OFF ROAD WATER TRUCK (A65056)
2017 KOMATSU...
