Ford 445a steering issues
/ Ford 445a steering issues #1
Shawng
Ford 445a
Hello,
Oil is leaking near the steering wheel out of the top of the column onto the dashboard. I took off the steering wheel and top bushing and noticed the bushing was pushed out of the column. The upper steering column is full of oil. Is that normal? Noticed bits of metal shavings. Do I have to take off the entire dashboard in order to get into the column so I can inspect seals/replace, etc. What might be causing this issue? Is this a motor or pump issue?
Any suggestions would be great.
Happy Holidays,
Shawn
/ Ford 445a steering issues #2
Hello,
No.
Yes.
Steering valve seal failure and possible rough/pitted surface on shaft.
Valve/motor.
Happy Holidays,
Shawn
Answers inserted.
Thank you for the quick and helpful reply, Rick. Really appreciate it.
Take care,
Shawn
generator trailer (A61569)
generator trailer...
UNUSED WOLVERINE ADB-13-1218R HYD AUGER (A62131)
UNUSED WOLVERINE...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
John Deere Z994R (A60462)
John Deere Z994R...
2004 DCT PUMP TRAILER (A58216)
2004 DCT PUMP...
UNUSED CFG INDUSTRIAL QH12R MINI EXCAVATOR (A62130)
UNUSED CFG...
