2019 Kubota with cab
/ 2019 Kubota with cab #1
Darren Hewitt
kubota B2650
I just this Kubota with the cab but the Hydro static transmission noise is unbearable. The cab is touching something making the cab a big speaker. Has anyone dealt with this with Kubota before and was it fixed. I had a open kubota before and it was not as noisy as this one.
I did read a post from some one and he said he took his in the dealer and they fixed it? I cant find you again. I like to know what the problem was.
thank you any help would be helpful.
sorry I better tell you the modal its a 2019 B2650
/ 2019 Kubota with cab #2
Welcome to TBN! You might want to post your question in the Kubota thread here on TBN... I am sure someone there will be able to help.
/ 2019 Kubota with cab #3
Welcome to TBN. You may find a solution to your issue on Orange Tractor Talks. It's a site specifically geared to Kubota owners.
/ 2019 Kubota with cab #4
If it's new and under warranty you can try complaining to the dealer. Tractors, even cabbed tractors can be noisy and hearing protection is a good idea. Lots of hard surfaces inside the cab will reflect the noise.
/ 2019 Kubota with cab #5
Welcome to the forum!
:tractor: I'm going to move this thread over to our Kubota section.
/ 2019 Kubota with cab #6
Might be useful to state which model Kubota you have. There are many different models that have a factory cab.
/ 2019 Kubota with cab #8
Hi. There have been a numerous posts complaining about the Hydro Whine on the Cabbed 2650, 3030 & 3000.
I have to admit, it is very annoying and LOUD.
Some owners have gone so far as to strip down the interior of their cabs and lined them with a sound dampening material.
If I had the time and patience, I would do the same on my B3000. But instead, I wear some good ear protection muffs.
Just keep searching the forum for Hydro Whine/Noise on those cabbed models.
/ 2019 Kubota with cab #9
I tested a cabbed B3030 and thought it was quite loud. That was back around 2012. Our L4240HSTC isn’t annoyingly loud, but it isn’t “car quiet” inside either.
/ 2019 Kubota with cab #10
The B3030and the B3000 are essentially the same tractor. I dont' even know why they bothered to make another iteration of the B3030.
Some think that the 3000 was slightly quieter than the 3030.... but I haven't been in a Cabbed B3030.
I have read that the L series and Grand's are much quieter than the cabbed "B" series.
/ 2019 Kubota with cab #11
I have a B2650 w/cab, and it'salways been very noisy. I always wear ear protection, but I found out that if I put heavy down pressure on the treadle it will reduce the hydrostatic noise significantly.
/ 2019 Kubota with cab #12
Exactly how "loud" is "loud"? Anyone get a decibel reading on this condition?
/ 2019 Kubota with cab #13
I had a B3350 that was loud. Ear protection was a must. I’ve downsized to a bx2380 open station which is a lot quieter.
/ 2019 Kubota with cab #14
Before condemning your own tractor for cab noise, may suggest visiting a dealership and try a couple others out just like yours that are cabbed as a comparison. You might be going down the rabbit hole for no reason if this is normal for this particular tractor. Cabbed models are always going to be noisy, because you are confined within, and there is no place for the noise to dissipate but up into the cab.
/ 2019 Kubota with cab #15
The cab on my JD430 Diesel is horribly loud inside. When using it to blow snow, I use ear plugs and hearing protectors, and it's still too loud. I just finished refurbishing the tractor and cab, and I mounted the cab on 3/16" thick rubber at all the mounting points. I haven't used it yet, but I'm wondering if that will help the sound level inside the cab.
I have some FatMat sound deadening material for my Nova project, I may try putting some it that on the roof panel to see if it helps.
HAD IT TESTED IT CAN GO AS HIGH AS 85 DECIBELS. I HAD A GOOD LOAD IN THE BUCKET AND THE SOUND WOULD CHANGE WHEN DRIVING ON UNEVEN TERRAIN.
/ 2019 Kubota with cab #17
Man... 85 db. That's pretty loud.
I believe that is right at the edge of doing damage to your hearing over a length of time.
I always wear good hearing protection in the cab of my B3000.
I do have to crank up the radio pretty high to hear it. :.)
John Deere 4044M (A60462)
John Deere 4044M...
2021 Chevrolet Silverado 1500 Crew Cab Pickup Truck (A61573)
2021 Chevrolet...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2006 TRAIL KING ADVANTAGE PLUS RGN/DETACH TRAILER (A58375)
2006 TRAIL KING...
KOMATSU FORKLIFT (A63291)
KOMATSU FORKLIFT...
2013 Nissan Pathfinder 4x4 SUV (A61574)
2013 Nissan...
