2019 Kubota with cab
   / 2019 Kubota with cab #11
I have a B2650 w/cab, and it'salways been very noisy. I always wear ear protection, but I found out that if I put heavy down pressure on the treadle it will reduce the hydrostatic noise significantly.
   / 2019 Kubota with cab #12
Exactly how "loud" is "loud"? Anyone get a decibel reading on this condition?
   / 2019 Kubota with cab #13
I had a B3350 that was loud. Ear protection was a must. I’ve downsized to a bx2380 open station which is a lot quieter.
   / 2019 Kubota with cab #14
I just this Kubota with the cab but the Hydro static transmission noise is unbearable. The cab is touching something making the cab a big speaker. Has anyone dealt with this with Kubota before and was it fixed. I had a open kubota before and it was not as noisy as this one.
I did read a post from some one and he said he took his in the dealer and they fixed it? I cant find you again. I like to know what the problem was.
thank you any help would be helpful.
sorry I better tell you the modal its a 2019 B2650
Before condemning your own tractor for cab noise, may suggest visiting a dealership and try a couple others out just like yours that are cabbed as a comparison. You might be going down the rabbit hole for no reason if this is normal for this particular tractor. Cabbed models are always going to be noisy, because you are confined within, and there is no place for the noise to dissipate but up into the cab.
   / 2019 Kubota with cab #15
The cab on my JD430 Diesel is horribly loud inside. When using it to blow snow, I use ear plugs and hearing protectors, and it's still too loud. I just finished refurbishing the tractor and cab, and I mounted the cab on 3/16" thick rubber at all the mounting points. I haven't used it yet, but I'm wondering if that will help the sound level inside the cab.
I have some FatMat sound deadening material for my Nova project, I may try putting some it that on the roof panel to see if it helps.
HAD IT TESTED IT CAN GO AS HIGH AS 85 DECIBELS. I HAD A GOOD LOAD IN THE BUCKET AND THE SOUND WOULD CHANGE WHEN DRIVING ON UNEVEN TERRAIN.
   / 2019 Kubota with cab #17
Man... 85 db. That's pretty loud.
I believe that is right at the edge of doing damage to your hearing over a length of time.
I always wear good hearing protection in the cab of my B3000.
I do have to crank up the radio pretty high to hear it. :.)
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
2019 Nissan Titan Crew Cab Pickup Truck (A55852)
2019 Nissan Titan...
UNUSED WOLVERINE SWDB-11 84W 84" DOZER BLADE (A57193)
UNUSED WOLVERINE...
UNUSED X-STAR GRAVEL LEVELER QUICK ATTACH (A57192)
UNUSED X-STAR...
2006 iDrive TDS-2010H ProJack M2 Electric Trailer Dolly (A55853)
2006 iDrive...
Rhino TW84 (A56469)
Rhino TW84 (A56469)
