   / Share Pics of People Hauling or Towing Something Wrong #13,541
LOL
TLDR is like one of the silliest sayings on the internet.....
Why bother responding if you are not going to read?
:2cents:
   / Share Pics of People Hauling or Towing Something Wrong #13,542
Since all Corvette hoods open to the rear it was clearly not installed correctly. Maybe just laying on there with the rear latch holding it.
   / Share Pics of People Hauling or Towing Something Wrong #13,543
I assumed the same, and prolly loaded on the trailer backwards.....
But still, if you have an ounce of common sense wouldnt you make sure the "bonnet" is latched properly??
   / Share Pics of People Hauling or Towing Something Wrong #13,544
It could have been loaded backwards or have been removed and just sitting on there. Thinking the rear latch would hold it. Either way I am sure it's not worth getting back after it was torn off and flew through the air. Aftermarket hoods are available for all of the generations. I am thining it's new hood time.
   / Share Pics of People Hauling or Towing Something Wrong #13,545
This is what happens when you have a heavy load on a spread axle trailer and drive through a big sink hole. The hole was so deep that the front trailer axle was off the ground and all the weight was too much for the frame to support it a the longer span from the fifth wheel to the rear trailer axle. Since it's an aluminum frame trailer, there might have been corrosion problems where the front axle hangars attach to the frame, weakening it.
   / Share Pics of People Hauling or Towing Something Wrong #13,546
Holy @#&%. But hey, his load securement sure worked!
   / Share Pics of People Hauling or Towing Something Wrong #13,547
I have always been told on any heavy haul trailer concentrated loads go over the axles. And single item concentrated loads can't go on aluminum trailers. Or in 3 or 4 axle vans. Because that's how you break them in half. The rear reel could have been over the axles and still scaled. The front one may have had to be there to scale with a 3 axle tractor but it's not the one that broke the trailer.
   / Share Pics of People Hauling or Towing Something Wrong #13,548
And loads with multiple deliveries are handled how?
   / Share Pics of People Hauling or Towing Something Wrong #13,549
There must have been some parmeter as to how much weight you can put in one spot that was ignored. Looks like aluminium,no? Probably would not have happened with a steel trailer.
   / Share Pics of People Hauling or Towing Something Wrong #13,550
What difference does that make. Once loaded it can stay where it is. If it scales it still will.
2018 TowMaster T-12D 7 Ton T/A Flatbed Trailer (A56858)
2018 TowMaster...
2023 Unverferth 3PT 6 FT Perfecta Field Cultivator (A56436)
2023 Unverferth...
White Metal Roof Panels (A55758)
White Metal Roof...
2007 Tymco 500X Air Sweeper, Turbo Diesel, 3876 Hours Indicated, mounted on 2007 International 4200 (A59076)
2007 Tymco 500X...
2014 Ford Taurus Sedan (A56859)
2014 Ford Taurus...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
