BX2380 - help identify where this part is from - fell off
   / BX2380 - help identify where this part is from - fell off #1
RobR5
Kent, Wa
Kubota BX2380
I have a BX2380 w/loader and drive over 60 MMM. I recently was doing some bucket work and heard a medal clanking noise then after backing up I seen this on the ground. It looks like some linkage however I have yet to figure out where it came from. The only I have noticed so far is the Mower seems to bounce more when driving around. I was hoping someone here might be able to help identify where it came from?
I appreciate any help on this one.
Rob
BX2380 - 77 hrs
Loader LA344
60 drive over MMM
Vacuum Bagger GCK60-26b
   / BX2380 - help identify where this part is from - fell off #2
Could it be a link from the loader levelling indicator? That's if you're loader came with one.
No it did not come with one.
   / BX2380 - help identify where this part is from - fell off #4
Possibly linkage for the parking brake lever...
   / BX2380 - help identify where this part is from - fell off #5
That seems about right, also check if both brake pedals and all shifting and control works - gear range, pto rear/mid select, pto engage, 3-point position control, 2wd/4wd, and cruise control?
Thank you. I will run through all those to ensure they all work.
   / BX2380 - help identify where this part is from - fell off #7
Also check the hand throttle lever...
I checked all these to ensure they all function and they all work with no issues. I suppose that’s good but confusing on what its from.
Rob
   / BX2380 - help identify where this part is from - fell off #9
I'm guessing it came off your mower then.
   / BX2380 - help identify where this part is from - fell off #10
That sir, is your diff lock rod.
I just dismantled and put a new transmission in a BX2380 last week. So I am very familiar with that machine.
25 TANDEM DUAL GOOSENECK TRAILER (A55745)
25 TANDEM DUAL...
2015 Ford Escape SE SUV (A55853)
2015 Ford Escape...
2025 MMS MS36C (A53317)
2025 MMS MS36C...
12 ft Shipping Container (A55973)
12 ft Shipping...
(APPROX. 20) 4' X...
1992 DFI PULL SPREADER (A58375)
1992 DFI PULL...
