BX2380 - help identify where this part is from - fell off
   / BX2380 - help identify where this part is from - fell off #1
RobR5
Kent, Wa
Kubota BX2380
I have a BX2380 w/loader and drive over 60 MMM. I recently was doing some bucket work and heard a medal clanking noise then after backing up I seen this on the ground. It looks like some linkage however I have yet to figure out where it came from. The only I have noticed so far is the Mower seems to bounce more when driving around. I was hoping someone here might be able to help identify where it came from?
I appreciate any help on this one.
Rob
BX2380 - 77 hrs
Loader LA344
60 drive over MMM
Vacuum Bagger GCK60-26b
   / BX2380 - help identify where this part is from - fell off #2
Could it be a link from the loader levelling indicator? That's if you're loader came with one.
No it did not come with one.
   / BX2380 - help identify where this part is from - fell off #4
Possibly linkage for the parking brake lever...
   / BX2380 - help identify where this part is from - fell off #5
That seems about right, also check if both brake pedals and all shifting and control works - gear range, pto rear/mid select, pto engage, 3-point position control, 2wd/4wd, and cruise control?
Thank you. I will run through all those to ensure they all work.
   / BX2380 - help identify where this part is from - fell off #7
Also check the hand throttle lever...
I checked all these to ensure they all function and they all work with no issues. I suppose that’s good but confusing on what its from.
Rob
   / BX2380 - help identify where this part is from - fell off #9
I'm guessing it came off your mower then.
   / BX2380 - help identify where this part is from - fell off #10
That sir, is your diff lock rod.
I just dismantled and put a new transmission in a BX2380 last week. So I am very familiar with that machine.
2017 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A57880)
2017 FREIGHTLINER...
2010 Chevrolet Tahoe SUV (A56859)
2010 Chevrolet...
24017 (A56859)
24017 (A56859)
2003 International 7400 T/A Heil 12 CuYd Dump Truck (A55853)
2003 International...
EZ-GO Utility Cart (A55853)
EZ-GO Utility Cart...
2014 GMC Terrain SUV (A56859)
2014 GMC Terrain...
