Snow Equipment Owning/Operating Pictures of your snow weapons
   / Pictures of your snow weapons #5,711
cat fever: Very nice setup Lynn!
What size (diameter) hydraulic hoses run from your HP24 to your blower? Roughly how long are they? Does Erskine provide guidelines in their documentation?
Reason I ask is I have a older setup that was marketed to wood splitter users. It uses a 21 gpm Prince pump. I swapped out the valve for one intended for hydraulic motor direction control. I believe my lines might be a bit small.
1" hoses. Erskine provided everything that was needed. Except the hydraulic fluid.
   / Pictures of your snow weapons #5,712
Here痴 my receipt. View attachment File Nov 19, 4 03 07 PM-1 copy.pdf
It痴 84? I opted for rubber edge and steel on back drag. Then changed my mind and ordered a poly edge. Probably going to put that on back drag for this year. I do residential plowing in subdivisions so I知 hoping the rubber and poly are nice and quiet at 3am. I will update as I use it. A couple of concerns may be my lack of traction with R-4痴 but I want to try this year and probably groove over the summer. To many nice sealed driveways to chain up.
   / Pictures of your snow weapons #5,713
I’m on my iPad so all kinds of strange characters. I’ll respond in am from computer so those will go away. 84 inch.
   / Pictures of your snow weapons #5,714
I don't know if you've used a pusher before, but they defy physics with how much snow they can carry!
Nice rig pokey, hla makes nice stuff.
Thanks I have not. Always used plows.
   / Pictures of your snow weapons #5,715
In West KY actually global warming has become our snow weapon by default. That was not the case 60-65 years ago. It has been several years since I've pulled off the bush hog and put on the grader blade.
   / Pictures of your snow weapons #5,718
Looks good.........
   / Pictures of your snow weapons #5,720
Added some flashing LED's to my snow weapon today.
Nice install. I've wanted something similar, but I have less than 1" clearance on the roof to get my tractor in the garage.
I have a magnetic xenon strobe that I slap on the rear implement that fires once per second. The rate is slow, but it is surprisingly noticable!
Advance SC750 28in Floor Scrubber (A53421)
Advance SC750 28in...
2021 Polaris Electric Golf Cart (A56859)
2021 Polaris...
2017 Dodge Charger Sedan (A55853)
2017 Dodge Charger...
2005 Dodge Caravan Van (A55853)
2005 Dodge Caravan...
1984 Trailmobile Enclosed Van Trailer (A55315)
1984 Trailmobile...
