MT125 Storage
/ MT125 Storage #1
jdeilus
Prince George, VA
LS MT 125 (still waiting for delivery)
My new tractor will be arriving next week. It’s a MT125 with a Loader and Backhoe. My problem is there is no where to store it to keep it away from the elements. I know my wife would not like it if I take her car out of the garage and move the tractor inside. Is anyone keeping their tractor outdoors? For now I am purchasing a cover that should cover the back of the seat to the front of the hood. I found it on Amazon for $79. Any one using one of these cover?
/ MT125 Storage #2
No cover. Mine has been outside about 20 of the 24 months I've had it. I built a new shed addition just for it, but sometimes I just don't feel like bothering with driving it inside.
/ MT125 Storage #3
I bought a Logic Shelter to keep my tractor out of the elements. It is 13'x20' and has plenty of room. When the shell wears out I will skin it with metal roofing.
/ MT125 Storage
I seen those at northern tools and Amazon. How long have you had the shelter?
/ MT125 Storage #5
Second year with mine. Neighbor has had his up for three years. They seem to wear well in our tough climate. I think I ordered mine from either Lowe's or Home Depot.
/ MT125 Storage #6
Logic Shelter are good. bought a costco shelter a few years back for a tractor i kept at our field. worked great and weathered just fine
/ MT125 Storage #7
You can also buy the replacement panels for them.
/ MT125 Storage #8
mine will be stored in the garage until the new building is completed, right next to the golf cart/estate maintenance/wife's toy. Those fabric shelters will quickly transport themselves into the next state when the winds kick up around here and a fitted cover will be an invitation to field mice to build nests.. the best defense against field mice/pack rats here is a hard building on a slab with very secure doors.. Owls and feral cats help too :) Even still, I've seen mice run into a building right along side someone opening the door.. they're cute but insidious.
Living in the desert has it's challenges.. but I get this view out my kitchen window:
/ MT125 Storage #9
I didn't like the idea of mine sitting out all the time either but I won't be able to add a lean to on the shop until next year. I decided to get a large tarp but didn't like the idea of it rubbing the paint off in the winds we get and then having to remove and reinstall it every time I needed to use or move the tractor. I then decided a metal carport would be better but I need it moveable as it would sit on the driveway in front of the shop that has 3 doors/bays and depending on what I was getting out, it would have to move. None of the metal ones were designed to be portable that I found so I made a PVC frame for the tarp I purchased. I secured the bottom PVC to boards that the tractor tires sit on to keep it from blowing away.
I must admit, in my head the cost wasn't going to be much but It ended up with a few revisions and total was about $350-400 including the tarp and boards, barely cheaper than a metal carport but it is what it is and its moveable. If I had a way to weld aluminum, I would have made it from aluminum. I actually considered buying a TIG welder for this since I've wanted one for years but couldn't justify the cost.
So far it has held up well and kept most of the elements off it. I just use the front bucket to drag it where I need it.
/ MT125 Storage
What size is that tarp and where did you get it?
/ MT125 Storage #12
Nice job. I bought a 13x20' Logic Shelter for the same cost and the frame is made of steel.
/ MT125 Storage #14
16 x20, TSC when on sale and had 10% off coupon. 20 x20 would have been better for the frame size I ended with.
/ MT125 Storage #15
I considered those but didn't think I could move it as needed and here it was closer to 500.00 when I looked. I "thought" I could build this all for about $250 initially, but as I progressed I made changes/improvements and PVC connectors are expensive little buggers!
I'm thinking I'll pour a 8' x 40' slab beside the shop and move this onto it for now and then add the metal lean to when funds are sufficient. That way I can anchor it to that slab and not have to move it any more.
/ MT125 Storage #16
I planned to move this by hand so it had to be light but one day backing out I didn't raise the bucket high enough and it caught the boards and moved it so I moved it back with the bucket, since then I use the bucket to move from bay to bay as needed, so it could have been heavier. Live and learn.
/ MT125 Storage #17
You do what you can and learn from the experience. Can't fault that.
2022 EZ-GO ELITE...
2022 EZ-GO ELITE...
2016 Boxer 700HDX Compact Skid Steer (A63109)
2016 Boxer 700HDX...
2348 (A64281)
2348 (A64281)
UNUSED WOLVERINE 3PT QUICK HITCH (A64281)
UNUSED WOLVERINE...
John Deere XUV825E (A61307)
John Deere XUV825E...
