MT125 Storage
/ MT125 Storage #1
jdeilus
Prince George, VA
LS MT 125 (still waiting for delivery)
My new tractor will be arriving next week. It’s a MT125 with a Loader and Backhoe. My problem is there is no where to store it to keep it away from the elements. I know my wife would not like it if I take her car out of the garage and move the tractor inside. Is anyone keeping their tractor outdoors? For now I am purchasing a cover that should cover the back of the seat to the front of the hood. I found it on Amazon for $79. Any one using one of these cover?
/ MT125 Storage #2
No cover. Mine has been outside about 20 of the 24 months I've had it. I built a new shed addition just for it, but sometimes I just don't feel like bothering with driving it inside.
/ MT125 Storage #3
I bought a Logic Shelter to keep my tractor out of the elements. It is 13'x20' and has plenty of room. When the shell wears out I will skin it with metal roofing.
/ MT125 Storage
I seen those at northern tools and Amazon. How long have you had the shelter?
/ MT125 Storage #5
Second year with mine. Neighbor has had his up for three years. They seem to wear well in our tough climate. I think I ordered mine from either Lowe's or Home Depot.
/ MT125 Storage #6
Logic Shelter are good. bought a costco shelter a few years back for a tractor i kept at our field. worked great and weathered just fine
/ MT125 Storage #7
You can also buy the replacement panels for them.
/ MT125 Storage #8
mine will be stored in the garage until the new building is completed, right next to the golf cart/estate maintenance/wife's toy. Those fabric shelters will quickly transport themselves into the next state when the winds kick up around here and a fitted cover will be an invitation to field mice to build nests.. the best defense against field mice/pack rats here is a hard building on a slab with very secure doors.. Owls and feral cats help too :) Even still, I've seen mice run into a building right along side someone opening the door.. they're cute but insidious.
Living in the desert has it's challenges.. but I get this view out my kitchen window:
/ MT125 Storage #9
I didn't like the idea of mine sitting out all the time either but I won't be able to add a lean to on the shop until next year. I decided to get a large tarp but didn't like the idea of it rubbing the paint off in the winds we get and then having to remove and reinstall it every time I needed to use or move the tractor. I then decided a metal carport would be better but I need it moveable as it would sit on the driveway in front of the shop that has 3 doors/bays and depending on what I was getting out, it would have to move. None of the metal ones were designed to be portable that I found so I made a PVC frame for the tarp I purchased. I secured the bottom PVC to boards that the tractor tires sit on to keep it from blowing away.
I must admit, in my head the cost wasn't going to be much but It ended up with a few revisions and total was about $350-400 including the tarp and boards, barely cheaper than a metal carport but it is what it is and its moveable. If I had a way to weld aluminum, I would have made it from aluminum. I actually considered buying a TIG welder for this since I've wanted one for years but couldn't justify the cost.
So far it has held up well and kept most of the elements off it. I just use the front bucket to drag it where I need it.
/ MT125 Storage
What size is that tarp and where did you get it?
/ MT125 Storage #12
Nice job. I bought a 13x20' Logic Shelter for the same cost and the frame is made of steel.
/ MT125 Storage #14
16 x20, TSC when on sale and had 10% off coupon. 20 x20 would have been better for the frame size I ended with.
/ MT125 Storage #15
I considered those but didn't think I could move it as needed and here it was closer to 500.00 when I looked. I "thought" I could build this all for about $250 initially, but as I progressed I made changes/improvements and PVC connectors are expensive little buggers!
I'm thinking I'll pour a 8' x 40' slab beside the shop and move this onto it for now and then add the metal lean to when funds are sufficient. That way I can anchor it to that slab and not have to move it any more.
/ MT125 Storage #16
I planned to move this by hand so it had to be light but one day backing out I didn't raise the bucket high enough and it caught the boards and moved it so I moved it back with the bucket, since then I use the bucket to move from bay to bay as needed, so it could have been heavier. Live and learn.
/ MT125 Storage #17
You do what you can and learn from the experience. Can't fault that.
Adams 5 Ton Fertilizer Spreader (A63688)
Adams 5 Ton...
High Hood All Aluminum Timpte 720 Trailer (A63689)
High Hood All...
2023 JOHN DEERE 450P LGP CRAWLER DOZER (A65053)
2023 JOHN DEERE...
2001 John Deere 1770 Planter (A63111)
2001 John Deere...
Lot of (Approx. 30) Venture Lighting 1,250W Metal Halide Bulbs - Fits Allmand Light Towers (A63689)
Lot of (Approx...
429888 (A61165)
429888 (A61165)
