Power loss between engine and PTO
/ Power loss between engine and PTO #1
EuroYanmar
Gold Member
Somewhere
Tractormatic
Good morning,
Yesterday I have made this excel sheet to have an idea of the power loss between engine and PTO.
I took the datas from official specifications. Some of these tractors are from european market and others from US market.
I hope I did no mistakes.
What do you think of this ?
Thanks for your help.
Phil
/ Power loss between engine and PTO #2
It's not clear on what "rating" you're using. There could be a substantial difference between Maximum Engine Horsepower and Engine Horsepower at rated PTO output speed. If PTO output speed of 540rpm is achieved at 1800rpm engine speed and peak engine horsepower is achieved at 2100rpm, of course there will be a loss on PTO power. I would bet the gap is reduced if the engine is run at peak output rpm. The problem is the PTO rpm may not be the standard 540rpm. :cool: (Ignoring the other speed "standards".)
There's more to it than just comparing numbers. Nice chart though. ;)
/ Power loss between engine and PTO #3
I always wondered about the slight discrepency between Engine HP and PTO HP. I don't think it's just the driveline losses. I think the measurements are different. Some shop vacs boast 6HP plugged into a 120 volt, 15 amp outlet. Doing the normal math, will show that is impossible. Even at the full 15 amps it falls many times short, never mind that the machines only draw a fraction of the 15 amps. I hope I didn't confuse things with the electrical example.
/ Power loss between engine and PTO #4
I may well be wrong here, but not too many years back, popular science was talking fuel efficiency in cars. At the time, automatics were only about 80 percent efficient compared to a manual. Both have losses. I know things have improved, but I think the type of drive your pto has certainly impacts the output.
Check how much heat you get in the oil in your transmission (either kind of drive). That heat is a big part of your power loss.
/ Power loss between engine and PTO #5
Depends on how the engine HP is rated. Are all engine accessories included? alternator, water pump, fuel pump, hydraulic pump, fan, plus any I missed... Are ou comparing an end of shaft ? Strictly, PTO related, there's the transmission. even in neutral, there're losses such as the transmission pump. Plus the PTO gear reduction, Seal drag loss, etc.
Notice the PTO power difference between open station and cab units... likely the a/c compressor power.
/ Power loss between engine and PTO #6
OP, you got it right. Tym's are known for this discrepancy. You're not the first one on this forum ho found this. But there is an error on the data sheet of Tym that even dealers are not aware of. One of the TBN useres was insisting and some higher Ups at Tym confirmed a lower loss to the PTO. I think this also applies to some Branson models.
/ Power loss between engine and PTO #7
Wondering if that's something related to the PTO clutch pack or something? If that's the case, then plenty of brands will have similar losses.
As I said on another thread, would be nice the the guys over at Nebraska Tractor Test Laboratory could test pretty much all the tractors. There is a test there of a TYM T603, by the way.
K5lwq, a member here on TBN, did test his brand new Branson 4815R (12x12 Transmission) on a PTO dyno. Here is the thread about that: https://www.tractorbynet.com/forums/century-branson/421282-branson-4815c-pto-dynamometer-test.html
Good morning,
Of course, you can imagine that I don't have a test bench at home to measure those numbers.
They come directly from the importers specification datasheets that everybody can download from their websites.
I guess there are in US some imposed industry standards when measuring the power of an engine or the power available at a PTO. (which one ? SAE, DIN, ISO etc.....?).
My mistake was certainly to mix, in the chart, european models and US models as the industrial measuring standards may differ from one side of the atlantic to another BUT : european Branson F47 is US Branson 4815 and european TYM T475 is US TYM T474 etc...
It stays IMHO that the power loss computed FROM THE IMPORTERS DATA for TYM is huge.......
Really a Tym official would be welcome if he could clarify this point.
Phil
/ Power loss between engine and PTO #9
Good morning,
Phil
83-87% pump efficiency for most. Awful for Tym. They must be using a centrifugal pump vs. probably a gear type for the others; wonder if they have an overpressure bypass like typical of others; wouldn't need with a centrifugal. That loss goes as heat that has to be cooled off in the hydraulic cooler.
Gentlemen,
I have fresh data from a TYM technical document for TYM T393, the former european version of TYM T394 but without DPF.
Anyway, the numbers are interesting :
T393 gear : engine 38,3 HP PTO 30,1 HP power loss (38,3-30,1)/38,3=21,4 %
T393 hst : engine 38,3 HP PTO 28,6 HP power loss (38,3-28,6)/38,3=25,3 %
I don't say this, TYM wrote it !
So our bavarian friend from Manitoba was 100 % right !
Phil
Hi RalphVa,
Very interesting explanation. Is it for HST models only ?
So, for Branson F47 (4815 in US) we have only 11 % power loss with the same model of KUKJE engine.
Does it mean the pump is different ?
Where is this pump located ? In the transmission or on the engine ? What kind of pump is it ?
Thanks,
Phil
/ Power loss between engine and PTO #12
Phil, keep in mind that the European Branson F47 uses a 3 cylinder Turbo engine, while the 4815 in the US uses a 4 cylinder engine, no turbo.
Regarding the pump, since we're speaking about PTO HP, on TYM and Branson, they use the power steering gear pump to engage the clutch pack. This applies to most brands actually.
I don't quite get what Ralph is trying to say about centrifugal pumps?
Hi PTSG,
I did not notice this.
Maybe in 2021 they will share the same engine because of stage V regulations.
I wonder if Ralph refered to a different system in the HST transmission.
If yes, the problem stays with the gear model tractor.
My opinion is that even if cab TYM T474 and cab BRANSON 4815 looks like they have a different transmission.
Phil
/ Power loss between engine and PTO #14
Interesting - the Op Manual for my 2009 Kubota M6040 ( Hydraulic shuttle, I.E - geared ) says - - 62 engine hp, 57 PTO hp.
/ Power loss between engine and PTO #15
It would be nice if all Manufacturers would actually test their ratings rather than compute or guess at it.
My Branson manual shows both HST and gear tractors have the same PTO HP. We know that isn't correct.
There was one Branson model, do not remember which one, that when it was first released it produced way more HP than they thought. The Branson rep for the west was telling me the story so the numbers might be off from my memory. The tractor was rated somewhere around 60 HP and on the PTO dyno it produced over 90 HP. A few of them made it to customers before it was corrected and are still out there. I bet those guys love their Tractors. :laughing:
/ Power loss between engine and PTO #16
I'm with K5. We can't really focus too much on any of these numbers. Most are just theory and not are actually tested.
For instance, TractorData specs for the Branson 3725:
3725R - Engine HP: 37HP - PTO HP: 33HP
3725H - Engine HP: 37HP - PTO HP: 32HP
I'm sure this is not accurate at all.
If the tractors were properly tested, I'm sure we would see a significant decrease on PTO HP over all brands.
/ Power loss between engine and PTO #17
The PTO is not driven through the HST. Even on CUTS with live PTO. When the tractor is stopped and running the PTO, the HST is in neutral and not pumping oil. So it should be consuming little or no power.
Is PTO HP rated when moving or when stationary?
/ Power loss between engine and PTO #18
Exactly. When the HST tractor starts moving, it's where the PTO HP will have a decent drop.
/ Power loss between engine and PTO #19
Hi RalphVa,
Thanks,
Phil
I don't know about HST pumps so much. Just surmising from what I learned about pumps in specifying and observing them in 31 years of chemical engineering. Just one of the things some of us did. Most of the pumps are located inside the HST casing. The 1025R's pump (looks like a gear one) is located at the top rear of it.
Ralph
/ Power loss between engine and PTO #20
If this is so, why such a big loss? If it's direct gear, there should be something like 2 or 3% loss. Makes more sense that it's the PTO hp like to a bush hog while the tractor is underway. Then, the PTO hp while standing would be up substantially.
Woods BB72 72in Rotary Brush Cutter Tractor Attachment (A61567)
Woods BB72 72in...
2015 Peterbilt 389 T/A Sleeper Cab Truck Tractor (A56858)
2015 Peterbilt 389...
Finn B-70TD Towable Hay Blower (A61166)
Finn B-70TD...
PALLET OF 15 4 X 8 GROUND PROTECTION MATS (A58214)
PALLET OF 15 4 X 8...
Massey Ferguson 4710 (A60462)
Massey Ferguson...
Dayton 32965 80-Gallon Horizontal Air Compressor, 22 Volts, 5 HP, 2 Stage, 3 Phase (A59076)
Dayton 32965...
