Posthole Digger PHD ?
/ PHD ? #1
Strummer
Strummer1%
What make a danuser so much more then the others ? I think mine is a Dan Evans . Had it about 20 years . Got it in a manhindra package .
/ PHD ? #2
Maybe construction? When I bought my JD I got lots of attachments including a Danuser digger. I've used it a lot and it seems well made. Dealer said "it's the Cadillac of diggers". Maybe he should have said Rolls Royce
/ PHD ?
Mine works fine . Was looking for a 12 in auger for mine . Was seeing used danuser Phd for anywhere from 1200 to 1700 . Just got me thinking what made them worth the extra money ?
/ PHD ? #4
I think they are built out of better materials...
I use to have a farm store PHD, it worked pretty good when the going wasn't too bad, but when conditions got worse, it started hard and many times wouldn't bore a straight hole. I found it VERRY annoying!
My brother bought a Bush Hog brand PHD, and yeaa it was much more expensive than mine, but it worked a thousand times better in tough conditions. When my brother said he was going to sell it, as he didn't need it any longer, I bought it from him.
Compared to the farm store PHD I had (that I sent down the road) the Bush Hog PHD was and is, a dream to use!!
I've used Danuser PHD, they are well made, work great in tough soil and last a long time...
SR
/ PHD ? #5
I have a hydraulic Danuser post hole digger that mounts on my loader. Well made.
/ PHD ? #8
There are three model Danuser models that work on a three point hitch. The "Cadillac" model is the F-8. Their web site calls it the "Cadillac" of PHD. The gears and bearings are very large. This model is rated to spin a 30" auger. The Tractor Supply Company model that costs $500 can handle a 12" auger. The forces on a 30" auger are massive compared to a 12" auger. Some of the other manufacturers like Landpride and Bush Hog manufacture PHDs that are rated to 24". The Danuser F8 costs $3500 new. You have to ask yourself what do you really want to do with the post hole digger. I have taken apart a Danuser F8 and the size of the internal components will shock you. Asking what the Danuser will do compared to others is like asking why does the rear end in your 1 ton pickup cost more than the rear end in you old Chevrolet Vega? They both move the vehicle.
/ PHD ? #10
I have always thought Danuser to be more suited to commercial or large farm/ranch applications. Ken Sweet
/ PHD ?
That makes sense and answers my question. Thank you .
/ PHD ? #12
For all the holes I bore, my TSC special is peachy and it's 20+ years old, hangs in a tree when not in use and cost me about 2 bills back then. Just used it the other day, greased the U joints, oiled up the coupler, swept off the wasp nests and hooked it up and bored a couple holes for broken fence posts. The day I spend 1200 bucks on a PHD is the day I commit myself to the nut house.:D
/ PHD ? #13
. . . Asking what the Danuser will do compared to others is like asking why does the rear end in your 1 ton pickup cost more than the rear end in you old Chevrolet Vega? They both move the vehicle.
If you are only driving to the grocery store once a week that Vega is going to be more than adequate. I've seen a Danuser drilling a nice hole. Yes, its a very well made tool. For my use, beyond overkill. With my last tractor, an L3400HST, I had a no name, beat up phd that I found on Craigslist. It worked fine for me - drilling over 100 6" holes in the rocky woods here. It sure wasn't pretty and it definitely wasn't a Danuser but it worked.
For my new to me L3800HST I just found a Land Pride PD15 in really good condition. It will be the last phd I buy.
If I needed a really rugged phd and used it constantly then I would probably spring for the big D.
/ PHD ?
After looking at the PHD now I’m not sure who made it . Had it along time and only name I see is Omni . It’s work fine for what I need. Had drilled 100’s of holes from 9 to 12’ . Was looking for an auger when I noticed the big price gap . If I ever buy another one it will run of my loader and not my 3pt .
/ PHD ? #15
Ya, I'm sure the Danhuser 3pt is one of the best 3pt PHDs out there. But at that price point you should seriously look as a loader mounted hydraulic one. Downpressure & reverse are nice, along with not blowing out your back hitching it up.
I have the small Danhuser hydraulic one now. 15hp or so tops with my hydraulic flow. So under the 25hp I had on my old 3pt one on a smaller machine. I can feel the less power. But I dig as fast with it due to the other advantages. Its also MUCH nicer to operate.
Omni is a gearbox OEM I believe. Not that there is much else to a PHD. Just a gearbox, frame, PTO shaft & auger. The gearbox is by far the most expensive complex & precision part.
/ PHD ? #16
Just $$ it out Canadian
DU6000 (G20/40) - $2999.00
DU6800 (J20/80) - $3499.00
DU9050 (F8) - $5299.00
without an auger.
It might be a Cadillac because its priced as one.
/ PHD ?
If for some reason I do buy another on it will be a hydraulic one for my fel
/ PHD ? #18
I'm looking at augers and Danuser is the only one I've come across that offers auger bits for different types of soils. That makes sense to me. Does it?
My tractor is a 25.5 hp Kubota B2601, so compact. Our soil here is tight clay full of shale. I mean all sizes of shale, which is from compressed clay, and then there are shale shelfs. Now nothing I can use will go through a shelf of rock. But I need something to deal with small, medium, and big rocks. Realistically I guess it would wallow them out. Trying to dig footings here, you are not going to have a nice straight trench.
My past experience was with an old PHD and a 33 hp JD970. It did great but our soil was not rocky. I also had a post pounder that worked well.
Here are the choices for Danuser's 20/40 PHD from their web site:
Plain Edge​
For digging in dirt, clay, sod, and other light-duty conditions.
Features:
Available in 40”, 52”, and 72” lengths for PTO diggers, and Models 8300, 8800, and 8900 hydraulic drives.
(click to see available auger bits)
Serrated Edge​
For digging in compact soils, light tree roots, and dry soil.
Features:
Hole Digger Head​
For digging in clay, caliche, shale, mixed limestone, frozen ground, and light rock. The most aggressive design offered.
Features:
Stepped (plain and serrated edges)​
Stepped tree planting auger for bulb type trees.
Features:
Available in 33” and 40” lengths for PTO diggers, and Models 8300, 8800, and 8900 hydraulic drives.
/ PHD ? #19
I've been happy with my Danuser and have the serrated edge. You could call Danuser and ask what's best for you.
2021 CAT 289D3 (A60462)
2021 CAT 289D3...
2021 Redirective Crash Cushion Guardrail (A61573)
2021 Redirective...
JMR Tree Boom Skid Steer Attachment (A61572)
JMR Tree Boom Skid...
2022 EZ-GO ELITE...
2006 Cadillac GM Superior Coach 6-Door Limousine - Only 21,567 Miles (A63689)
2006 Cadillac GM...
2007 JLG E400AJP TELESCOPIC/SCISSORING MANLIFT (A52709)
2007 JLG E400AJP...
