Snow Attachments Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #31
my front loader mount will lift as high as my loader arms can lift, but thats because its fed by rear hydraulic lines. front mounted units that power off of mid pto's cant lift very far up. ready to blow roof.jpg
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #32
my front loader mount will lift as high as my loader arms can lift, but thats because its fed by rear hydraulic lines. front mounted units that power off of mid pto's cant lift very far up. View attachment 676555
HA that would work but not sure they make one for the GC series LOL
man could I clear a bank nicely with that unit, don't want to move to maine and be my friend do you ? LOL
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #33
Sweet. I looked at the rear pump/ hyd blower idea. If you have to blow it from that high, thinkin you need a bigger tractor. I do enjoy watching vids from Europe, where they have mega snow chompers.
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #34
i dont ever need to go that high, but when i clear the snow that sheds from barn roof it needs to go pretty high. if i dont clear it it melts and runs into barn, and the horses cant get in or out. snow shedding e side BEFORE 2008.jpg snow shedding E side barn DURING 2008.jpg snow shedding e side AFTER 2008.jpg
when i used to have to clear this with rear blower, i would have to use bucket to bring down some snow, then turn around and blow it. took about 4+ hours per side. with the front blower i raise unit up and drive until front wheels touch snow, back up and lower and go forward again. maybe have 30 minutes per side at most now.
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #35
idaho snow is bad enough. actually my 45 HP is probably a bit underpowered for this setup. 55HP would probably be better, or 75 even. but i got a great deal on this tractor back in 2011. and it really has been a great tractor. for normal 6-8" snowfall days, this unit just speds along nicely and throws white junk far away so the wind doesnt simply blow it back onto the roads. when the snow is too wet, or early in season i run an 84" plow. is alot faster than blower. but leaves those pesky berms. and i truly hate berms.
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #36
work it until it screams is my motto :)
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #37
this brings up a point I wonder about.
I plow my own road (2011 silverado 2500HD Boss 9.5 XT v blade) and end up creating 10ft high banks. been clearing using a gc1710 or MF1532, this year will use my own GC2400. wondering if front mount blower lifts high enough to allow "climbing" a bank to blow it down. or does a rear lift higher for this?
I don't have a problem with the banks, I lift the blower and move into it, when the front lifts I back out move forward and repeat - we should be pretty close to the same temps, I'm not dealing with a lot of slush / frozen stuff, we stay pretty cold, so the banks drop when I undercut them - the blower set up is nice unit it cuts in well and moves it easily, at least twice a season I have to move back the road banks as the plows do not follow the contour of the road, neighbor is surprised how well the blower cuts it and moves it back as they are pretty high....
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #38
ok thats is helpful, thanks
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #39
I'm considering the purchase of a front-mounted snow blower for my bx2380.
Any pros / cons or issues of a front-mounted snow blower, along with vendors / models?
It all comes down to your snow amounts and conditions. Where are you?
If you get a whopper 6" snow once a year, you're wasting your money. If you get 6" 3 times a week that's a different story. Blowers are a neat tool for the right conditions and don't get me wrong I have both, plows and a blower but plows just like blowers have their place in snow removal. It's your conditions that matter.
A guy in the middle of a wind blown field can get blown shut 6' deep with a "small" snowfall. grsthegreat has snow sliding off his barn roof ie; concentrated to say the least :laughing: and need's it way away for the next snow. These are just 2 "conditions". What's yours.?
   / Pro/ cons and issues with front-mounted Snow Blower for Compact Tractor #40
Since nobody asked how close are you to other houses (or other things that would restrict you from blowing snow in that direction)? IS it wide open and do you get lots of wind coming from multiple directions? Before I got my front mount blower I used a 2 1/2 ton 4wd dump truck with a 10' plow. By middle of January the banks got so big I had to borrow a tractor with a loader to push them back. It's not an issue now as the blower will throw the snow over a 6' bank. But at the same time it doesn't make snow banks like a plow. I have almost no use for my loader in the winter. In fact about 75% of the winters I've gone through I've left the blower on for the entire season.
I will caution about leaving 4" of packed snow. Rain will turn that snow into slush if you get a January thaw. The plunging temps that follow will turn it into a skating rink. Your location will make a difference of course but for me, I just keep the blower high enough to skim over the gravel. Once the driveway freezes I raise the shoes so I'm not allowing it to build up any further.
A snow blower is slow and a front mount might actually be even slower since you loose power if the PTO power has to go out the rear of the tractor then through a gearbox that changes it to go to the front. But you will not struggle to see both corners and with HST you can just set the pace that allows you to keep the PTO speed up.
UNVERFERTH 330 - 19-INCH EXTENSION KIT FOR RIP-STRIP TOOLBAR PART # 63186G (A55315)
UNVERFERTH 330 -...
2002 International 9200i Truck (A56435)
2002 International...
Deere 35G (A53317)
Deere 35G (A53317)
MARATHON 20KW GENERATOR (A58214)
MARATHON 20KW...
SHOPBUILT PUSH BAR FOR FORKLIFT (A52708)
SHOPBUILT PUSH BAR...
1996 Isuzu NPR Box Truck, VIN # 4KLB4B1R8TJ000333 (A57453)
1996 Isuzu NPR Box...
