Circular saw arbor problem
/ Circular saw arbor problem #21
I’d drill out the hole before attempting to grind the arbor. BTW 40 teeth on that diameter blade is still too many for that thickness material.
/ Circular saw arbor problem #22
I looked up that series of saws. All appear to have a 5/8 shaft and all except the 6460 have a 5/8 arbor. That suggests to me that the blade mounting flanges are interchangeable. I think if you got the flanges for the 8 1/4 saw, they would fit your saw perfectly and allow the use of current 10 1/4 blades.
Interesting. Thanks for mentioning that. I can certainly look for the inner spindle washer from the 8 or 10" saw (the 6470). But I suppose if that is fine then my grinding idea should be OK too. I re-checked last night and the 5/8" blade arbor fits very snugly on the spindle. Seems like less play in that than the spindle washer itself, or at least no more.
Rob
/ Circular saw arbor problem #24
My guess is an engineer said it would be better for a slipping blade to spin on a 50 cent nut/washer than to spin and chew up an armature or output shaft that could cost $10-20. Wholesale prices of course. 5/8 to 3/4 you could easily fix if you spent a few thousand to get an old milling machine and some cutters.
If that's the case, they obviously revisited their decision since all these other Milwaukee saw models have a 5/8" spindle with non-flanged washers.
Even if true, this saw is not going to get anywhere near enough use for that to be a concern.
Just to follow this up...
After investigating the situation, inspecting several other circular saws I have, and finding that newer models use 5/8" arbor blades with flat spindle washers I went with the simple, cheap and effective fix. I ground off the flange on the inner spindle washer. The 5/8 arbor blades fit the spindle very snugly, just like other saws. The non-flanged washer is just like other saws. This saw has worked perfectly after the mod and allowed me to do a bunch of long rips of 3" thick hard maple slabs, which is the whole reason I needed this saw.
Thanks for the tips, especially downsizingnow for your comment about the other saws in the model line.
Rob
P.S. If anyone wants the two 3/4" arbor 10.25" blades I have which are no longer of use (both need sharpening) let me know.
3" Steel Posts (A66408)
3" Steel Posts...
2012 TEXAS BRAGG COOL DOWN TRAILER (A65643)
2012 TEXAS BRAGG...
1996 Aspen FP601 T/A Fracking Pump (A64194)
1996 Aspen FP601...
Wolverine TL-12-72W 72" Skid Steer Tiller (A62679)
Wolverine...
2013 Ford F-550 Altec AT37G 37ft Bucket Truck (A61573)
2013 Ford F-550...
2015 PETERBILT 567 TANDEM AXLE DAY CAB (A66091)
2015 PETERBILT 567...
