Battery Longevity
/ Battery Longevity #1
OrangeAgain
Albany, Vermont 05820
2015 Kioti RX7320PC, 1983 Kubota L275 4WD, 1981 John Deere 2440 2WD row crop tractor
I bought my Kioti RX7320PC in 2015 and have 216 hours on it. It's been stored in my barn and in the winters I often have a trickle charger on it. Occasionally, regardless of the season, the battery isn't strong enough to start the tractor, like yesterday. I just have to put my 30A - 60A charger on for several minutes and "she" starts right up.
Could the battery be old enough to replace?
Could something in the electrical system be draining the battery charge?
/ Battery Longevity #2
The battery in my Kubota is the original one from 2010. It's never failed to start. I would remove the ground terminal from the battery the next time you think it'll be awhile before you use it. If the battery still is loosing charge then it's most likely a bad battery. If not then you may need to dig further.
/ Battery Longevity #3
Many possible causes of the battery situation. My motorcycle, tractor, ATP & both lawn mowers are out in the cold, under the carport or storage shed. I put a trickle charger on them about every three months during the winter. Otherwise, the charge may be short of starting. More serious - the charge level can get so low the battery could freeze and split open.
Take the battery to NAPA or the like. They have the equipment to check the batteries status.
/ Battery Longevity #4
I think battery quality is hit and miss nowadays like a lot of things. Easier to skip the QA check on the way out the door and let the retailer figure out how to deal with the customer.
I’ve had some last a few months, and others last years. I’ve bought expensive ones and cheap ones. Tried trickle chargers or not. Absolutely no pattern. Some cheap ones are good and last years and years of pure abuse. The next one doesn’t last 4 months in the ideal conditions. One thing for sure though, over charging and heat destroy batteries. One fella told me the way some are constructed, there is not enough room below the plates for sediment to collect and when it does, the plates short out. Seems to have truth but who knows. Batteries are almost as good a topic as oil and grease :)
Get ones with the best warranty locally so you can trade them in as need be, easily. That’s my solution.
/ Battery Longevity #5
"often have a trickle charger on it"
Why..."often"?
Why not just LEAVE the trickle charger on it?
I leave a trickle charger on each of my (16) Winter stored batteries.
/ Battery Longevity
I have a nearby Kioti dealer, John Deere dealer, Kubota dealer and O'Reilly Auto Parts. Do any of those have better batteries (reliability & warranty) than the others?
/ Battery Longevity #7
I have found with expensive or cheap batteries to keep a trickle charger on them especially if there is down time between uses BUT do not leave it on all the time. Place the trickle charger on a timer so that it is only on for 30 min. or so once or twice a day. Life on batteries in equipment that is dormant for weeks or months at a time has doubled in some cases. Since retirement even the car and trucks do not see regular use so they also have trickle chargers to compensate for the vampire draw of the security and computer systems that are on all of them now days.
/ Battery Longevity #8
If I am going to have a battery failure it's when it turns cold. I just had 2ea 3 year old, sealed, quality batteries on Lawn care equipment fail within the week. Other side of the coin is that on most of my tractors, I forget just when I installed the current battery.....don't use any kind of maintainer on any of them....but the ones that are seldom used, I charge them up every so often...when I think about it. Cold climates surely aggravate this problem.....not all that cold here in N. Tx.
/ Battery Longevity #9
Electrical trouble shooting 101: Start with a fully charged known good battery.
Remove the battery, fully charge it (>12.6 volts) and then have it load tested. This will tell you if the battery is known good. After you know this, then meaningful electrical trouble shooting can begin.
/ Battery Longevity #10
The place to begin is having battery professionally tested. When you are sure you have a good battery,lose the 30-60 amp charger and use a maintainer type charger instead. There's a difference between trickle and maintainer chargers. I highly reccomend Deltran battery tender charger-maintainers. You can leave them connected 24-7/365. While extreme cold and heat effect battery life,over charging or long periods in low stat of charge has far more effect than temperature. There are hundreds of threads on the subject if you search.
/ Battery Longevity #11
""BUT do not leave it on all the time"
Kinda tough to do while away from the batteries for 6 months at a time.
All the time hookup works just fine when using quality built trickle chargers.
I have used 6 month continued hookups for many years, with many batteries.
EXCELLENT battery life results!
/ Battery Longevity #12
The little battery on my standby generator, which was started rarely, was failing every two or three years. I put a "battery maintainer" on it that's on 25/7/365 and it's lasted for many years.
/ Battery Longevity #14
Every two years. Batteries crimp a strap on to bind the plates together. Vibration as well as hot and cold cycles loosen the bond. At rest the battery may register as a 12.6v but as soon as a load is put on it, *POOF* the battery is a 10.4 volt as one of the cell drops off. Once in a while a battery seems to hold in there forever for years.
/ Battery Longevity #16
I have never for the life of me understood why vehicle/equipment electrical lsystems with 35 amp and up alternators don't boil batteries. Put a five amp charger on a battery and it will be boiling eventually. You can't tell me that charging systems are that sophisticated, especially older ones.
You would think that if you drained your battery and got it started with a 100 amp plus alternator, it would destroy the battery, but it doesn't.
/ Battery Longevity #17
That's my experience also, I have 5 maintainers running now.
One of the worst things we can do to led-acid batteries is to not use them.
/ Battery Longevity #18
The field strength is variable. In other words, the voltage to the field windings is ramped up and down to accommodate the load. Forcing a heavy load on a discharged battery can be done, but it isn't good for the life of the battery.
A discharged battery takes the load it can accept, not necessarily the load it is fed.
/ Battery Longevity #19
But doesn't a high capacity alternator really stick it to a dead battery? I mean the way it's connected, the alternator doesn't know the load is a dead battery and not a bunch of other stuff,
/ Battery Longevity #20
As I was taught in trade school, the battery is the storage and doesn't necessarily experience all the loads firsthand because of the body ground. The alternator is supplying the load and the load is getting used by what ever is running the current before it gets to the battery.
Over at Quora, James K. Klang, writes:
I am a battery scientist with over 40 years experience.
Most of the answers given refer to the traditional automobile where once started the alternator provides most electrical power for vehicle operation. The battery is only required to deliver sustained power for various vehicle loads when the engine is not running,
There are, however, vehicles that make more demands on batteries in order to improve fuel efficiency and reduce pollution. When these vehicles come to a stop light during normal operation, the engine shuts off, thus saving fuel that is wasted in idling. All the electrical loads in the vehicle are then supplied from the battery rather than the alternator that produces nothing while the engine is off. This can normally occur for different lengths of time depending on traffic conditions, but when the driver removes his foot from the brake or touches the accelerator, the engine restarts almost instantly and the alternator recharges the battery.
Obviously, both the battery and starter must be tailored to this scenario. The battery is normally larger and has features to improve its resistance to cycling and charge acceptance. The starter system must be designed for many more starts and do so quickly so as not be very noticeable by the driver. To keep the battery in condition that will prevent its failure to restart during a stop event, a battery monitoring system (BMS) is added to constantly measure the battery痴 performance and keep it in a satisfactory operating condition. The vehicle will not shut off the engine if the BMS or vehicle computer does not approve because of a weak/discharged battery or if some other safety or comfort system would be compromised. Most manufacturers are implementing a version of this system on their new vehicles because of pressure to comply with fuel and emission standards. It only takes a short time to get used to this system (it has been on hybrid vehicles for a long time). Many people are uncomfortable with this change, because it is different. But it is the future and will soon be the standard.
It used to be that batteries were heavily drained by forgetting to turn some electrical load off, like lights. Now most cars have run down features that turn off any load after a period of time.
Source: Is it true that car batteries are only used when starting the car and then it's the car alternator that provides the electricity? - Quora
2013 CATERPILLAR 120M2 MOTOR GRADER (A63276)
2013 CATERPILLAR...
2016 International DuraStar 4300 Auto Crane 5005H 5,000lb. Flatbed Crane Truck (A64556)
2016 International...
2019 MULTIQUIP TOWABLE GENERATOR (A63276)
2019 MULTIQUIP...
UNUSED JCT QUADRUPLE TINE BALE SPEAR (A65055)
UNUSED JCT...
Conveyor Belt (A64194)
UNUSED FUTURE SZYMJ HYD MINI STUMP GRINDER (A65055)
UNUSED FUTURE...
