ponytug
Super Member
Sorry to hear it. Try a new fuel filter, after double checking the prefilter again.
When you redo the fuel lines, you probably can get rid of that after market fuel pump.
FWIW: I run SeaFoam in all of my diesel, primarily to keep algae growth down, but also for keeping fuel lines and injectors clean. After you have changed the fuel filter and convinced that you have solved your problem, you might want to consider adding a can just to clean things out.
All the best,
Peter
All the best,
Peter
Well it was about 4 minutes that it ran perfect. Then same thing. Motor slows way down, then dies out. Let it sit for a minute, starts right up and then repeats.
Going to have to go through the entire fuel system.
Don't have enough time to work on it right now as I'm to busy with my regular job.
Wish there was a P.T. mobile guy to call for repairs.
