Diving into Ham Radio... uh oh!
   / Diving into Ham Radio... uh oh! #111
I will probably do some more playing around but here are my measurements if anyone cares. Shown are EFHW-8010-2W Antenna tune measurements: Band / (AS IS antenna length 130ft) SWR, and SWR after antenna shortened 2ft. Sorry I don't know if it is possible to embed a file so here is the raw plain readings I took. The 'red' numbers are well above 3. You can see I sort wiped out my 10m bands trying to tune for 80m.
Tuning the antenna before the license? Naughty, naughty! de N4HHE
OK with something ultra low power such as a nanoVNA but not with a transceiver and tuner.
Fixation on SWR is soooo CB. You would like the antenna to be resonant in transmitting frequencies but the big concern is reflected power. Not the ratio of forward to reflected.
   / Diving into Ham Radio... uh oh! #112
But isn't any power being produced that isn't going out the antenna, coming back? Where else is it going?
   / Diving into Ham Radio... uh oh! #113
It bounces back and forth. Losses attributable to SWR are minimal. Can heat the finals in your transmitter so it is not good. But "SWR" is something that seems to have one if the most successful marketing departments known to man the way newbies and others obsess.
A 3:1 VSWR results in 1.2 dB power loss. Path loss through the ether may be 100 dB. 140 dB for GPS.
   / Diving into Ham Radio... uh oh! #114
Isn't the situation more dire at higher frequncies?
   / Diving into Ham Radio... uh oh! #115
Nope. Exactly the same.
Higher frequencies have a lower noise floor which helps hear signals which would fall below the noise on other frequencies. Is little use to build radio front ends with low internal noise for HF (<30 MHz) than for 2m (144-148 MHz) and above.
There is loss with impedance mismatch but tuners do not cure that, they only keep it away from the transmitter.
   / Diving into Ham Radio... uh oh! #116
I remember running this ANDREWS 1-5/8" stuff up my tower for my UHF Repeater. I always assumed everything got worse as operating frequency went up. HF seemed so easy except for the real estate required for the antenna.
In my case I have the real estate... the 'polluted' view is the problem for both my wife and/or neighbors depending on my placement.
   / Diving into Ham Radio... uh oh! #118
Ham friend of mine was telling me how he excorised (sp?) his house for RFI. Last issue was some LED pot light PSUs making a ton of noise.
I have a battery to hook up my rig so I plan to shut all house power off and start diagnosing the sources. Maybe this afternoon when my wife leaves for town. :D
I have a desk lamp in my home office/shack that is now coming on for 'no reason'. Maybe that has to go? Should be interesting to isolate and reduce RFI sources. I'm guessing this won't be a quick task.
   / Diving into Ham Radio... uh oh! #120
It could be the cheapest or the most expensive consumer device in your house causing RFI.
2022 John Deere 4052M MFWD Compact Utility Tractor with 400E loader - Bucket, Forks and Grapple (A55314)
2022 John Deere...
UNUSED 5'3" METAL BULL SHOOTING TARGET (A52706)
UNUSED 5'3" METAL...
2016 Peterbilt 320 T/A EZ-Pack Front Loader Garbage Truck (A54814)
2016 Peterbilt 320...
UNUSED FUTRE FL-ESC220 ELECTRIC STONE CRUSHER (A52706)
UNUSED FUTRE...
2017 Ford Explorer AWD SUV (A53424)
2017 Ford Explorer...
2017 Ford F-450 Crew Cab Mason Dump Truck (A53422)
2017 Ford F-450...
