Posthole Digger Augers for Land Pride PD10?
/ Augers for Land Pride PD10? #1
TnVmax
Oak Ridge, TN
Kubota BX1860
I have a Kubota SubCompact BX-1860 with a Land Pride PD-10 Post Hole Digger.
I bought it with a 9" auger, but now I'm wanting a 4"-6" auger to quick-change for smaller projects.
I do know the auger has to be short, 30" long because of the lack of lift clearance of the sub-compact tractors.
Where is the cheapest place to buy a new auger (shipped) for the PD-10?
Are there any aftermarket augers that will fit the PD-10?
Thanks in advance!
/ Augers for Land Pride PD10? #2
Looks like it has a standard 2" output shaft. If that's the case you can likely buy augers about anywhere for 2" shafts. TSC usually has them at a reasonable price.
The problem I'm finding is, The PD-10 was designed for small SubCompact tractors (like mine), and with their limited lift height, LandPride designed the boom for augers that are only 30" long, but yet I still find my auger dragging on uneven ground when moving the tractor around.
The aftermarket augers I've found are 36+ inches long.
I was hoping someone knew of a manufacturer for the PD10's, or, suggest a dealer for Land Pride who offers good discount (my local dealer wants full MSRP, and I bought the Kubota, MMM & PD10 all from them...)
/ Augers for Land Pride PD10? #4
Does your tractor have a way to adjust your lift arms? Not sure about the small tractors but the medium and larger have adjustment holes to change the height of the lift arms...if possible it may give you a few inches at the end of the boom
