Stake pocket stabilizers?
/ Stake pocket stabilizers? #1
tallfreak
North Mississippi
na
I need stabilizers on my 20ft 12k trailer. I dont have room for a swivel screw type jack, and I dont want to remove my rear stake pockets.
I was thinking abkut getting some 1.5x3.5 7 guage steel tubing and drilling holes down it so I could pin it through the stake pockets. I would make it with a removable foot so I can pull them out if needed. When traveling I would just leave them in the highest position.
Is there anything wrong with this idea? Are the stake pockets strong enough? The heaviest thing I load at this moment is my ck3510 with loaded rear tires and a 1000lb ballast.
Of course I would have a lot of this tubing left over i would probably use to make some stake pocket D rings and a spare tire carrier.
/ Stake pocket stabilizers? #2
Do your ramps not have supports on them?
I have slide in ramps. I didnt want folding ramps.
I have been carrying a couple of concrete blocks with me to support the tail of the trailer.
/ Stake pocket stabilizers? #4
If the load, once on the trailer, keeps some weight on the legs, how will you pull the pin to raise them?
Bruce
/ Stake pocket stabilizers? #5
Bruce
Bruce,,,, always the thinker..... Good point my friend!!!! :D
/ Stake pocket stabilizers? #6
mount them in front of the rear pockets. they dont have to be exactly at the rear
Bruce
They don't have to be on the ground. They can be a few inches off the ground and then the trailer will just tilt a little. I havent had any issues with the bricks yet. They are just a pita
/ Stake pocket stabilizers? #8
You could put a short 4x4 under the leg, crossways. Then if there was any weight on the stabilizer, just pull forward or backwards and it would roll off the 4x4.
Bruce
All I'm asking is about the strength of the stake pockets. I dont see why they couldn't handle it, but I wanted a second opinion.
/ Stake pocket stabilizers? #10
The stake pockets should be strong enough. Isn't that where most guys anchor there chains or straps to when tying down?
Thats where I tie down but its not holding the majority of the weight of the tractor and its 4 stake pockets used when securing the tractor. Same when I have a car on the trailer. One strap at each corner.
/ Stake pocket stabilizers? #12
Yep...
/ Stake pocket stabilizers? #15
The cheapest way is a small floor jack throw it down in the center rear of the trailer and jack it up to take the loading weight,
when loaded drop it and throw it on the tongue or where ever it's handy.
Other wise your idea will work once you have figured out how high off the ground to pin the legs before you load :thumbsup:
/ Stake pocket stabilizers? #16
That’s when you realize the back of the trailer tilting down a little means the tongue lifts the rear of the truck and you discover you’re parked on a slope. The trucks front tires do nothing to hold the vehicle from rolling when in Park.
/ Stake pocket stabilizers? #17
Thatç—´ when you realize the back of the trailer tilting down a little means the tongue lifts the rear of the truck and you discover youæ±*e parked on a slope. The trucks front tires do nothing to hold the vehicle from rolling when in Park.
40+ years ago I had a rig called a "Mico Lock" which would hydraulically lock all 4 wheel brakes.
Worked great with a heavy boat on trailer, and steep slippery ramp.
Looks like it is still being made/sold.
$400 now, on E-Bay.
/ Stake pocket stabilizers? #18
I have this on my F600 it is awesome although a little sketchy having the main brake like ran through the cab to the little lever lock
/ Stake pocket stabilizers? #19
Minco has numerous brake lock systems and they have had them for a great many years from lever locks to electric locks.
They are a good locking device, did find one issue a few decades back with vacuum boosted brakes if you had real good vacuum in your booster and set your brakes with the electric lock you could have problems getting it to release as after flipping the switch off you had to apply greater pressure to the brake system then was applied when you set it as the 0ne way check had to be released by the greater pressure.
Brake Locks | MICO, Inc.
/ Stake pocket stabilizers? #20
Absolutely!!!! With the electric version you need to pay attention to how "tight" you set the brakes.
The mechanical version doesn't matter since it's a valve/lever. Down side as mentioned is brake fluid plumbed into the cab.
x (A68191)
x (A68191)
1999 TRAILMASTER PUP TRAILER (A67714)
1999 TRAILMASTER...
11R24.5 Tires - Set of 4 (A68134)
11R24.5 Tires -...
Cub Cadet LT 1042 Riding Mower (A65579)
Cub Cadet LT 1042...
21601SFL (A66738)
21601SFL (A66738)
2005 Acura RSX Coupe (A66738)
2005 Acura RSX...
