   / Share Pics of People Hauling or Towing Something Wrong #13,311
   / Share Pics of People Hauling or Towing Something Wrong #13,312
I’m kinda surprised the ramp held. I was debating putting a 3600 pound roller in a 7,000 pound covered trailer and decided against it because I was worried about breaking the ramp. I put a ditch witch on my 7,000 pound open trailer and after bending a ramp and pretty much bottoming out the springs I decided it was a better candidate for my 14k trailer. IMG_9100.JPG
   / Share Pics of People Hauling or Towing Something Wrong #13,313
I知 kinda surprised the ramp held. I was debating putting a 3600 pound roller in a 7,000 pound covered trailer and decided against it because I was worried about breaking the ramp. I put a ditch witch on my 7,000 pound open trailer and after bending a ramp and pretty much bottoming out the springs I decided it was a better candidate for my 14k trailer. View attachment 674258
I believe there is no ramp to that trailer,, it is a tilt bed,, drive directly onto the trailer, without ramps.
From the look of the picture, he did not even get the trailer to tilt all the way back to flat.
There is a winch on the trailer,, I would bet the winch has pulled the trailer back towards flat, as much as possible.
   / Share Pics of People Hauling or Towing Something Wrong #13,314
I meant the skid steer in covered trailer picture.
   / Share Pics of People Hauling or Towing Something Wrong #13,315
Yea, THAT would be hard on ramps, but, the long tracks do a good job of distributing the weight,, that might have saved the ramps,, :eek:
   / Share Pics of People Hauling or Towing Something Wrong #13,316
Yea I wouldn’t be surprised if my roller would load the ramp worse. But at the point of overloaded the skid steer was I wouldn’t be surprised if it bent the the back of the trailer. 7,000 pound trailers in general are pretty light duty and covered trailers have even less frame.
   / Share Pics of People Hauling or Towing Something Wrong #13,317
I’m kinda surprised the ramp held. I was debating putting a 3600 pound roller in a 7,000 pound covered trailer and decided against it because I was worried about breaking the ramp. I put a ditch witch on my 7,000 pound open trailer and after bending a ramp and pretty much bottoming out the springs I decided it was a better candidate for my 14k trailer. View attachment 674258
How much does the trencher weigh? I had a decent size trencher on my 7k trailer no problem, ramps are just a piece of 2x12, although whatever wood it is might be stonger then steel! (I found the boards under leaves in my woods when I bought my house, with no rot!)1064330086.jpeg
   / Share Pics of People Hauling or Towing Something Wrong #13,318
They just got the title wrong, its not a makeshift trailer, its just a heavy duty tow dolly!
I wonder how they managed to turn? I could see it trailering okay going straight or even a real slight curve, but a tight turn? Pretty sure there is no turn table on that tilt bed.
About a year ago I saw a guy towing about a 24' gooseneck car trailer with a second vehicle strapped to the dove tail. I wondered then how he turned. It's possible he had a turn table affair but I didn't see one.
   / Share Pics of People Hauling or Towing Something Wrong #13,319
You actually could do it by tying it down by the front tires and leaving the steering unlocked.
Or the really sketchy way is just tie it down by the center of the front axle (or frame if its IFS) and lock the steering so it can pivot around the tie down.
   / Share Pics of People Hauling or Towing Something Wrong #13,320
That's a pretty good answer. I do think on a tight turn the front wheels would need to shift forward (inside) and backward (outside) even with them unlocked or the rear axle of the motorhome would need to skid sideways which wont happen, but...
2003 Big Tex 10PI...
2021 TAKEUCHI  TB260 (A58214)
2021 TAKEUCHI...
2015 International Durastar 4300 SBA 4 x 2 Water Truck, VIN: 3HAMMMMN4FL510006, Cummins Turbo Die... (A59076)
2015 International...
EDGER & FRONT TINE TILLER (A58374)
EDGER & FRONT TINE...
2011 INTERNATIONAL WORKSTAR 7400 SBA 6X4 DUMP TRK (A52706)
2011 INTERNATIONAL...
4 Unused Montreal ST205/75R15 Trailer Tires (A55787)
4 Unused Montreal...
