strantor
VERY COOL! This is very ambitious and you seem to be chugging along, this gives me some guilt about letting my own larger projects grow stagnant. You inspire me. Thank you for sharing.
I am curious about your hydraulic system design. By my rough estimate, 19GPM @ 3,000PSI would require at least 40HP. Since you're using a 15hp engine I assume you are using 19GPM at lower pressure (for fast transit) OR 3,000PSI for digging/pushing, but not both at the same time. In my experience this kind of arrangement is addressed with load sensing valves that control the displacement (swashplate angle) of the pump. These systems get pretty complicated pretty quickly. I have pondered simpler ways to do it, and I'm curious if you've found one of these simpler ways, or if you're using load sensing. Actually I'm just curious in general, about all of it, mostly the hydraulics.
12.7GPM main pump, 6.3GPM auxiliary pump
The flow rate of the main pump is adjustable from 0 to 100% regardless of the engine speed. With the size of the cylinders, around 6GPM will be a good shoveling speed. The total (19GPM) will be used only for movement on a good surface. The 6.3GPM can also be used to drive an independent accessory (eg auger, brush cutter) while the 12.7GPM will remain fully available for the movement and activations of all cylinders.
2800lbs push (pull) force at approximately 2.5km / h. (3000PSI)
