What am I Missing? 1991 Ford F-350 hood latch
/ What am I Missing? 1991 Ford F-350 hood latch
Makes no sense to me. Does the lower latch just catch on the edge of the hole in the hood?
Perhaps my snowplow solenoid is sticking up just a little to high (about 3/4" above everything else). The only adjustments I see for anything are at the lower latch. IMG_20201015_091037_hdr.jpg
Again... your picture & the picture in post #50 look exactly like my functioning hoods do.
You are missing NOTHING.
The latch hooks on the hood under the spring. NO extra pieces.
Thanks. I lost a lot of hair thinking on this. I will try some adjustments.
Here's a pic I found from a 92 F150 (same hood). The mark in the small recessed and reinforced area should be where it latches.View attachment 673145
Sorry. You are absolutely correct. I can't believe I didn't see this sooner. Thanks for not giving up on me and reposting.
/ What am I Missing? 1991 Ford F-350 hood latch #76
My Suburban's passenger door does that sometimes. For some reason the latching fingers don't open all the way when the door is opened. Then, when you close it, they hit the striker, forcing the latch to close even further before it engages the striker. From that point on, I'll never be able to close the door without first opening the handle to re-open the latch. Sometimes that doesn't work, and I'll have to use my fingers to open the latch all the way. Lubing it all up and operating it without closing the door a few times helps. But sometimes, even if it's clean as a whistle, all the lube in the world won't help a worn out part.
So now that you have it figured out, just make sure it's clean, lubed and not bent, or it'll happen again on you.
Thanks for reposting. I understand it now.
/ What am I Missing? 1991 Ford F-350 hood latch #78
I just moved the Latch out a little for the photo. It operates properly.
If the latch is staying in that position it might be sticking or the spring is broken.
Your latch looks cleaner then most I'm use to, maybe it was replaced and not adjusted properly.
When you close the hood does is go down all the way and pop back up or does it stop before it's closed? If it stops does it fell like its rocking on the latch in the center?
Good advice. Thanks
/ What am I Missing? 1991 Ford F-350 hood latch #80
I just didn't want to looking for the non existent catch the rest of your life lol
2021 CATERPILLAR D5 LGP HIGH TRACK CRAWLER DOZER (A52709)
2021 CATERPILLAR...
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
401 (A52706)
401 (A52706)
KBH Tender Trailer (A61307)
KBH Tender Trailer...
2022 Caterpillar 289D3 (A60462)
2022 Caterpillar...
2014 WESTERN STAR 4900 SF (A60736)
2014 WESTERN STAR...
