the old grind
Super Member
- Joined
- Jul 21, 2012
- Messages
- 5,308
- Location
- Mid-Michigan
- Tractor
- NH T-1520 HST, NH TC33DA HST, Case DX26 HST, .Terramite T5C, . NH L785
So I believe I'll getting one of your valves when the new pump house actually gets built and plumbed for the final time. Are there situations that it doesn't make sense to do so? I was looking on the web for reviews and thoughts on them and ran across a guy who thought the valve created back pressure on the pump and pipes. Is this correct or no?
There are users like myself who are thrifty with water use, and as Valveman says there are situations where little to nothing is gained by installing a CSV. My 3/4 hp shallow well pump with '20 gal equivalent' bladder tank cycles 3-4 times/day, and I'm an example of minimal benefit. It's 7:00 PM here now and my pump has been off since my shower this morning. (I can hear it from upstairs) I might get one cycle when doing dishes once or twice/week, and a load in the washer is usually just two cycles. And yes, 'going off the porch' is very routine for me vs flushing the jar.
... I'd like to think a well company would look at my well if it was his own.
Guys like that are rare, but out there. We have a company of skilled workmen in our area whose services are outstanding and whose work is freely explained to customers with technical or engineering background. I met them 25 yrs ago*, and had them come out last Summer to check a pump for me on another property, expecting it to need pulled and/or replaced.
Two guys showed up, tested flow and amp draw, then talked me out of doing more while explaining why. (Oh, I grilled them.) They were there for two hours and charged me $75 for driving a rig, replacement pumps, and supplies if needed across the county for the call.
*B Taylor & Co put in a 1hp two wire submersible on poly for a friend. IIRC the well was 180' and the pump set ~140' and ground water at ~60'. Glenn added a hydrant by the pump and ran three 'chic-chic-chic-da-da-da' sprinklers on 50' 3/4" hoses at once on it for decades to water lawn and his "asparagris". The pump outlived him and still runs. Note that we're retired and don't use as much water as we age.
Question for those who know: Was using wire a gauge smaller than I would have installed to blow like a fuse if lightning struck? How about for providing a soft start? Hard to argue with longevity. The last pump I helped pull just down the road had shattered vanes. We replaced it with ~what what was there because we didn't know how/whether to reassess or change what Marty had. Well & pump were 15 years old, and Taylor didn't install 'em.
