What did you do on or to your LS Tractor today?
   / What did you do on or to your LS Tractor today? #1,481
I traded in my XR4140hc for a MT342 with hst and cab. Drove it around and played with it. I like the new features they added. Still don't want to scratch it yet.
I made an overview video of the new tractor that shows the new updates. If you want to see it: NEW LS Tractor MT342 Overview - YouTube
   / What did you do on or to your LS Tractor today? #1,482
Reworked 30 yr old gravel driveway. No more weeds/grass, I can actually see gravel and a much better outline of the drive. Used a 6 box blade. 747D2A88-B8E3-49E4-AFA9-DB504B1BB0AD.jpeg
   / What did you do on or to your LS Tractor today? #1,483
I thought about the brass plate thing but he said engraved soo ....
You can order some fairly elaborate brass address plates if you want to go that way.
I haven't had much luck with solar outdoor feature lights. They last a year or two at most and are made in a way you can't repair them. Can you run low voltage wiring out to it? They make quite a few decently styled LV landscape light fixtures and LED lamps for them. I have to be very careful with roadside lighting though. I'm on a bad hill on a narrow road and don't want to do anything that might distract a driver's eyes.
Maybe I’m overly cautious but I don’t put name on mailbox (or outside indicator). I would just put house number or address.
   / What did you do on or to your LS Tractor today? #1,484
Yeah, I thought about that. I may just put a number on it. As a college professor I don't exactly want students to know where I live.
However, I live on a private drive with 3 other neighbors total, so the only people that would see it are my neighbors, or someone specifically driving to my place, as we live at the end of the road.
   / What did you do on or to your LS Tractor today? #1,485
Reworked 30 yr old gravel driveway. No more weeds/grass, I can actually see gravel and a much better outline of the drive. Used a 6 box blade.View attachment 672735
Looks great. Did you have to pick up all the grass clumps by hand? I need to do he same.
   / What did you do on or to your LS Tractor today? #1,486
Yep, carried a 5 gal bucket and spent a lot of time bending over to collect the clumps by hand. But it sure makes a big difference getting that stuff out of the way.
   / What did you do on or to your LS Tractor today? #1,487
23 degrees here this morning so I have probably waited to long. I think I will do the grass and clump removal next spring. A driveway should look like a driveway.
   / What did you do on or to your LS Tractor today? #1,488
This is what i did today.
I got stuck in the pond by doing something dumb but was no problem got the 4wd 50 hp tractor hooked to side pulled semi flat let FEL w/grapple down in mud to hold moved big tractor to the rear hooked up to draw bar put the tractor in granny low ran jumped on the LS raised the FEL put in reverse to help, it came right out shut LS tractor off let down loader then shut down the big tractor.
My Wife could not help as she had a cast on her leg.
I know i will probably get some post on safety but sometimes you do what you have to do.
   / What did you do on or to your LS Tractor today? #1,489
Your poor wife had a worried look on her face. I hope she kicked you in the arse with that cast for it.:D. Glad you got it out.
I read that about 5 times and I still have no idea what he said.
12 X 20 CAR PORT (A58214)
12 X 20 CAR PORT...
2005 JOHN DEERE 317 SKID STEER (A52709)
2005 JOHN DEERE...
telescope boom (A56857)
telescope boom...
1998 Club Car Electric Cart (A56859)
1998 Club Car...
2013 John Deere 824K Wheel Loader (A56435)
2013 John Deere...
Weld on excavator thumb EK1212 (A56435)
Weld on excavator...
