What else do you do with forks besides lift pallets?
   / What else do you do with forks besides lift pallets? #411
Removed an old landing.
Had to dig out the old post base.
   / What else do you do with forks besides lift pallets? #412
How about moving rocks. Dug this one out with the backhoe, but coould only drag it with the front wheels off the ground. A loaded bucket off dirt bring the front end down. But getting under the rock with the forks I was able to pick it up and move it. Other pictures shows it resting on a log while waiting for the wife to come home and tell me where she wants it. Would like to stand it on an edge if it is stable. This is one of many rocks dug and moved. P_20201010_142139_LL.jpgP_20201010_142128_LL.jpgJon
   / What else do you do with forks besides lift pallets? #413
How about moving rocks. Dug this one out with the backhoe, but coould only drag it with the front wheels off the ground. A loaded bucket off dirt bring the front end down. But getting under the rock with the forks I was able to pick it up and move it. Other pictures shows it resting on a log while waiting for the wife to come home and tell me where she wants it. Would like to stand it on an edge if it is stable. This is one of many rocks dug and moved. View attachment 672643View attachment 672644Jon
That's a Keeper! You need to dig up its twin. Envious, I have to haul all mine home.
Moved a 2000 lb damaged culvert that I set in the wrong place. That puppy was heavy.
   / What else do you do with forks besides lift pallets? #415
I am buying a set, if I can find something decent, to move brush.
I have piles, slide the forks under, strap the brush on.
   / What else do you do with forks besides lift pallets? #416
I have a cabbed tractor so I bought 48" Forks. At least now I can see the fork tips. I need to get my camera system installed this winter for even better vision.
   / What else do you do with forks besides lift pallets? #417
Install a really big door.
   / What else do you do with forks besides lift pallets? #418
Yup, Good For Doors!
   / What else do you do with forks besides lift pallets? #419
Don't do this at home kids...
   / What else do you do with forks besides lift pallets? #420
If you buy a set you will continually find more uses. Here I am holding a 1500' spool of 1" tubing. This is used in our sugarbush for collecting sap.
JMR Tree Boom (A57149)
UNUSED SET OF FUTURE 13', 200AMP JUMPER CABLES (A58375)
UNUSED SET OF...
500 Gallon Poly Tank (A59076)
500 Gallon Poly...
500 BBL FRAC TANK (A58214)
500 BBL FRAC TANK...
2005 Chevrolet C4500 Altec Bucket Truck (A56858)
2005 Chevrolet...
UNUSED FUTURE MINI 29" PALLET FORKS (A58376)
UNUSED FUTURE MINI...
