I Need a Bigger Tractor
/ I Need a Bigger Tractor
VIDEO: So you want to TRADE UP for a new Tractor? - TMT - YouTube
My local Kubota dealer tells me Kubota will announce price increases of around 15% in January 2021. Dealer has a short period to order now at 2020 prices for delivery in 2020 or as available.
Thanks for the education Jeff. I was aware of rear axle width and tire ballast and made the appropriate adjustments on the L3901 prior to delivery with Ag tires. I wasn't aware of tractor weight, so I will research that more fully..
Jethro - the Grand L is not in my consideration. I have looked at them but they are pricey compared to an MX. Personally I think the MX is a better deal, but that is me.
/ I Need a Bigger Tractor #23
/ I Need a Bigger Tractor #24
Don’t get excited; a 45 acre lawn may be a little much. Look at alternatives such as wild prairie grasses and flowers. Much more beneficial than a large tractor and big lawn that eats into your spare time.
Now if you are really serious for a big lawn get a cabbed tractor with Geo positioning. That way you sit in air conditioned comfort doing whatever while the tractor steers itself!
I've really enjoyed viewing Messick's youtube videos. I always appreciate the education I get watching his videos.
/ I Need a Bigger Tractor #26
I certainly understand. :). I tend to over analyze and over buy, thats usually where my regrets bite me. A MX is a fine machine. I saw where cruise control is standard on HST and it comes in handy on long stretches. Might want to hang on to the 6 footer for tight areas and backing under trees. Good luck.
/ I Need a Bigger Tractor #27
We have lots of ground to mow and i do worry about the fawns and turkeys, So i usually wait till late june to start cutting the larger areas. I think the mx size tractor will work for you.
We have the same wildlife issues here too. The turkeys I don't so much worry about, but their eggs, I do. We've found several turkey eggs this spring and I waited until late June to start cutting to avoid any fawns, but by that time, the grass/foilage was quite high and left large clumps in the wake of the bush hog. I do like the MX, especially because of the additional leg room and power. I'm leaning toward a cab model vs an open station, but I haven't made my mind up yet. The cost difference between the two is about 10K.
/ I Need a Bigger Tractor #29
I like the MX5400/6000 and I may opt for a cab model.
The cab model will have a moderately higher center-of-gravity, therefore cab model will be a little tippier on hills relative to an open station model.
Cab model weighs about 700 pounds more than open station model. The extra weight is almost all over the rear wheels, which is good. A light tractor needs plenty of weight on the rear wheels in order to maintain traction applying 60-horsepower.
/ I Need a Bigger Tractor #30
Is a Kubota Grand L in your considerations? It would be difficult to have buyers remorse when it comes to features. The HST Plus transmission is top of the line. I believe cost is in the neighborhood of $5k over a comparable MX.
Value represents itself to each of us differently. Having said that, you don't know what you do not know. Almost all Grand L buyers have previously operated economy tractors, including moi. In nine years using this site I have never seen a 'Grand L' owner express regret on spending the extra money. Grand L tractors, but not Loaders, are entirely assembled in Japan and shipped to USA intact.
If you are retired or approaching retirement age and want a tractor to grow old with, give Kubota's Grand L models serious consideration. Your aging body will thank you every hour you spend on the (air-ride) seat.
Many more buy Toyotas than Lexus.
I like the L3901, it is agile, gets into tight places and is easy to drive - but it has one serious flaw. The ingress/egress of the tractor is a real pain. You can forget about getting off this tractor quickly.
You have to buy a Grand L in order to have a tilt steering wheel. No tilt wheel on the MX.
/ I Need a Bigger Tractor #31
I have 80 acres. Mixture of pine stands, open grass fields and 25 acres in two lakes. I upgraded to a M6040 about ten years ago. It's sure a whole lot easier to get any work done with the larger tractor. I mow nothing out beyond the lawn around my house. I leave it all for the local wildlife.
My M6040 is open station and hydraulic shuttle shift. With my HD Land Pride SGC1560 grapple, 1550# of RimGuard in the rear tires & 1050# Rhino rear blade, the tractor weighs - 10,100#. More than adequate weight & power to get any job done for me.
/ I Need a Bigger Tractor #32
SDT - The PTO specs on a 10 foot Rhino is 25HP minimum. The L3901 PTO HP is 32, so it will pull the implement, but I do agree the L3901 is marginal for a 6 foot rotary cutter. Even though I have used the cutter for the past 4 months, I have had no issue with pulling it. My hills are not extreme, so that may be a factor. The MX6000 has 52 PTO HP, so it should be no problem to pull even a TS12 cutter (specs on this cutter require 35-50PTO HP).
As far as whether the Rhino cutters can be used with a Kubota, I am not sure. Obviously, something to consider and investigate. Thank you for your input..
Mower manufacturer's HP requirements are intended to sell mowers. Yes, it will pull it across a well kept golf course but not in what most of us consider "normal" rough cut conditions. It is also too light for use in steep conditions.
I use a HD 6' mounted cutter with my L6060 and, it's all she wants in many of the conditions that I mow. Stall guard (if on) will routinely reduce ground speed to zero in heavy cover.
Yes, my L6060 would pull a 12' BW but the going would be slow in many conditions and the PTO shaft is too close to the drawbar to allow use of the optional self leveling hitch on the LP cutter. I investigated this thoroughly before deciding to buy a 15' BW for use with my M9960.
SDT
/ I Need a Bigger Tractor #34
City folk move to the country and mow and mow and mow, they want everything to look like a park! Then they go the zoo to see the animals!
Country folk don't mow and mow and mow, we like to see the animals in their natural setting! Then we go to the city to see parks!!!
SR
/ I Need a Bigger Tractor #35
SR
Well put !!!!
SR
Well, that pretty much sounds like me! When you've got wide open spaces of land, there is not much else to do at the moment. We're going to enlist the help of a wildlife habitat biologist to help us plan for proper land use so we're not mowing all the time. But, I am still going to have to get a bigger tractor...
/ I Need a Bigger Tractor #37
A 15' batwing sure is nice to sneak under tree limbs without having to put the tractor under them. And there's nothing wrong with used equipment. Even if you're not comfortable making an assessment yourself, a hired mechanic, farmer, neighbor, etc that would check things over for you would be worth it. Remember this, bigger "commercial" machines and equipment that was built for 40 hours/week would have a wonderful retirement puttering around you field edges for? 20 hours a month? :thumbsup:
/ I Need a Bigger Tractor #38
You don't need a wildlife biologist, you just need to stop mowing! That the wildlife was doing just fine before you took their habitat away...
If I was you, I'd want a bigger tractor too, they are just so much nicer, and in many cases safer, to own than a little tractor on a bigger property.
SR
/ I Need a Bigger Tractor #39
If it was me I would wait until you've made a firm commitment on what you are going to do with the land. If it means cutting as much as you say I would move from the MX to an M, maybe in the 70 HP range. It might be a little large for things like a small garden but as long as you have open space around it you can still do it. Very few people say "Gee, I bought too big of a tractor". Personally I think I would try to find someone else who will cut it as you want it cut. However that may not be an option. If you are going to cut it at some point you may think about going the next step and bailing it. That's why I think an M series would be a better option. Sure you can do it with a smaller tractor but as you're finding out being close to the minimum HP requirements means going slower. Also with bailing extra weight is a good thing.
SR
I get it, but I'm having a hard time just leaving things as they are. It looks nicer when its cut. Must be the "city boy" in me....
Light plant Generac Magnum (NONE TITLED) (A63569)
Light plant...
DYNAPAC CC524HF DOUBLE DRUM ROLLER (A64279)
DYNAPAC CC524HF...
2014 John Deere 7230R Tractor (A63111)
2014 John Deere...
2020 TROXELL CONCEPT 130 BBL STEEL VACUUM TRAILER (A63569)
2020 TROXELL...
2021 Unverferth 432 Rigid 4 Row 36-inch 3PT Ripper Bedder (A63688)
2021 Unverferth...
MORBARK WOOD HOG 6400 XT HORIZONTAL GRINDER (A60429)
MORBARK WOOD HOG...
