New garage time!
/ New garage time!
Not sure why you created those squares in the middle of your gate?
Since you didn't put diagonal bracing in your gates, you should really run a cable from the top hinge corner to the opposite bottom cable so they wont sag on you. I would also install inside metal brackets to your corners so they don't come apart.
The squares are just a byproduct of the diagonal bracing on the gate. I couldn't just run screws and box the 4x4's without some support or it would sag and wouldn't be square. I do have steel cable that I'll be running diagonal from the top of the posts to bottom of the next post, but I'm not sure how much I'll actually need it. The posts are already tied to the other posts by the 2x4's, so they really shouldn't be able to sag.
/ New garage time! #802
I think he meant to say you should run a cable on the gate itself, from the top hinge corner to the opposite bottom corner on the gate, so they won't sag on you.
/ New garage time! #803
Like this....
/ New garage time! #804
I get the cable as a belt and suspenders approach, but when the pickets are screwed on, won't that be a whole bunch of additional diagonals?
/ New garage time! #805
Not if vertical to match his fence.
/ New garage time! #806
Unless he puts two screws in the top and bottom of each picket, the pickets will offer zero resistance to a folding parallelogram.
/ New garage time! #807
I guess I was thinking he would put screws through the top and bottom 4x4s and diagonal 2x4s. I'm not dismissing the cable idea.
/ New garage time! #808
And add hanging weight to the gate.
/ New garage time!
Have to install the steel cables yet but the gates are basically done. They swing nicely and open and close nicely. When it's closed you can't tell it's even there. After I get the cables installed I'll do pickets on the back side as well.
/ New garage time! #811
Good job on your fence/gates.
Looks like a fence without any gates from the front.
KC
/ New garage time!
KC
That was the goal. With the gate closed I didn稚 want to be able to tell there even was a gate. I知 going to cut the top posts evenly and put solar light caps on them.
/ New garage time! #813
:thumbsup:
I like hidden gates.
/ New garage time!
:thumbsup:
I also very seldom use that side of the house. I would have put up a strait fence but I didn't want to lock myself off from that side.
/ New garage time! #816
Smart! Blocking machinery access to a section of your property WILL bite you eventually.
Looking good... I like it! The pointed tops for some reason is reminding me of F Troop or Wild West fort construction.
/ New garage time!
Nice night shot of hte garage. I'm just waiting on trusses at this point, about 2 weeks out.
/ New garage time! #818
Great job, looks very nice
/ New garage time! #820
That cable isn’t needed with the diagonal brace already there.
If it was made out of metal, I would agree with you. But since it's made out of wood, and exposed to the elements, the cable is needed.
2001 VIBROMAX W1106PD ROLLER (A66091)
2001 VIBROMAX...
2019 John Deere 460E 46 Ton Articulated Dump Truck (A64194)
2019 John Deere...
Ground Protection Mats (A64194)
Ground Protection...
2006 Ford E-250 Cargo Van (A64556)
2006 Ford E-250...
2020 Cushman 1200X Gas Utility Cart (A64553)
2020 Cushman 1200X...
2022 EZ-GO ELITE...
