California
Super Star Member
- Joined
- Jan 22, 2004
- Messages
- 16,793
- Location
- An hour north of San Francisco
- Tractor
- Yanmar YM240 Yanmar YM186D
Listen to rScotty on this stuff. He had a tractor shop. I'm just an enthusiastic owner.California ...do you try to put it in gear to move the fluids or just let it sit and run - not sure if the ATF will harm the pump(s)? Also - I saw on another forum someone mentioned a sea foam product called Hydra Trans Tune.
Seems to me when you first drain, you might determine there is so much crud that any cheap oil that won't hurt it would serve for the first, short, flush, just to flush out the majority of the snot. (and load it into the strainer that you just cleaned). Then quality stuff for the subsequent flushes.
An A/T shop might have good advice for a flushing additive, SeaFoam or whatever they use. Looking at the parts diagram for Powershift, I think much of the transmission internals are same as the A/T in a small Japanese car of the same era. Datsun 510 or something. So an A/T shop's procedures are applicable.
Yanmar generally put that strainer, a wire mesh filter, behind a triangular plate and in most cases at the bottom of the sump where you can poke in a rag to clean the sump floor. I have no idea if 2210 is built that way.
But my comments are just armchair speculation. Listen to rScotty and the others who have BTDT. I've always wanted a YM2210BD but that's as close as I've been to what you have.
