5220ch or 4720C
/ 5220ch or 4720C #1
YanmarFever
Elite Member
Eating a melon..
Branson 4520r 5520C- Yanmar FX235-D - Bad Boy rogue mower
Im shopping for a Branson 4720CH or a 5220C with no loader, I need it as a spraying machine.
Does anyone know what I can expect to pay for one.
Thanks Ernie
/ 5220ch or 4720C #2
I would be guessing around $30,000 without the loader.
/ 5220ch or 4720C #3
Just thinking for myself, I would be hard pressed to buy a tractor without a FEL and 2 rear remotes, even if I planned on never needing them (plans can change unexpectedly).
/ 5220ch or 4720C #4
Four years ago I paid right at $30K for a 4720 with loader and cab. I don't know how much prices have gone up. Why not just call a dealer and ask? I kind of agree with Slim. Having a loader will also help with resale whenever that time comes. (Ever notice how people on forums never seem to mind telling you to spend more money?:)) Branson loaders do come off very easily.
/ 5220ch or 4720C #5
Every time I check the oil in my 8050 I cuss the loader frame,
Branson ran the loader frame rails higher then the original frame rails,
I have to twist and shove my hand under the throttle cables to reach the dipstick to remove it,
then to try and install it without getting it dirty.
Quite often I will scrape some of the skin off the back of my hand doing a simple check.
I notice that one of your options mentioned was a CH is that a cabbed tractor with a hydrostatic transmission?
I would not car for a hydro for spraying to much variance in ground speed to pto speed.
/ 5220ch or 4720C #6
About a year and a half ago, I looked at the 4720h 4720ch and 5220h.
Went with the 5220h . Loader, backhoe,
Medium duty cuter, box blade pallet forks
And a set of rear remotes for the backhoe.
Don稚 remember exact price. Was under $35
Delivered.
I believe
The 4720ch was $2000-$3000 more.
The 4720h was $2000-$3000 less.
/ 5220ch or 4720C #7
I agree that a geared tractor is far better for spraying than is a hydrostatic. I do quite a bit of spraying with my hydro though. On flat ground it is fine. On hilly ground it requires attention. I permanently installed a Garmin GPS that I had laying around to help me maintain a constant speed. It helps a lot for spraying. It not only tells you your speed, it helps keep track of where you have and haven't sprayed (Not as accurate for location as the ultra expensive made for farming GPS's though, but much better than guessing). A decent spraying system will maintain a constant nozzle pressure regardless of PTO speed.
Checking oil and changing the oil filter on the 4720CH is a pain too because of the loader frame. I try to plan my oil changes around when I have the FEL off. It is under a 5 minute job to remove or re-install the FEL.
/ 5220ch or 4720C
Mr Haney is giving me a good deal !!:laughing:
I got a good price from a dealer in Florida 5220 cab and loader for $32,5
I think I will go with that.
At first I didn't want the loader because I already have a 3510i and a 4520R with loaders.
Once I found out it wasn't that much more with the loader, minds quickly changed!
Thanks to all
/ 5220ch or 4720C #9
Very nice! Congratulations! You are building a nice fleet of tractors!
/ 5220ch or 4720C #10
Couldn't possibly be worse than the Ford loaders over the years. Try doing any engine servicing, much less work with those things in the way. I have 3 Fords and none have loaders for that very reason.
/ 5220ch or 4720C #11
I have never seen a Branson 8050 without a loader,
and very few pictures of one without a loader there is one on this forum as can be seen the frame rail is very small and everything is acessible.
https://www.tractorbynet.com/forums/century-branson/197308-branson-8050-cab.html
Now add a loader frame and it is gone, removing the loader will not make much difference unless you were to unbolt the entire wrap around loader frame.
front view
see the yellow handle
way down there
going for it
further down yet
Got my hand on it
Got it out checked the level now to get it back in without getting it dirty
the throttle cables enjoy pulling hair out
/ 5220ch or 4720C #12
Lou, I thought the one on my 4815 was bad. Holy cow, I think I would have to rig up a longer dipstick and install a tube. Should not be difficult to modify something. That is just ridiculous. :laughing:
/ 5220ch or 4720C #13
I agree. I will never complain about my hard to get to dipstick again. A Branson engineer should get a 'D-' for the day he approved that design. Can you add something to it to add to the length? And maybe add a larger diameter tube to guide it down to the original hole?
/ 5220ch or 4720C
I would cut cut the top off and weld an extension on it, than you can reach it easier
/ 5220ch or 4720C #15
I have thought about adding a longer tube and lengthening the dipstick, which would probably be the best way,
but I am more likely to lengthen the handle end of the dipstick.
But it will have to be a nice cold day when I have the material on hand and I've had to take my gloves off to check the oil level and not much going on. :laughing:
Slingshot Field Hub 2.0 (A63117)
Slingshot Field...
2025 ZJG ZJ-380 Mini Stand-On Track Loader Skid Steer (A59228)
2025 ZJG ZJ-380...
2013 DODGE CHARGER (A63276)
2013 DODGE CHARGER...
BRIGGS & STRATTON PORTABLE AIR COMPRESSOR (A64276)
BRIGGS & STRATTON...
2025 Auger Bits Skid Steer Attachment (A61567)
2025 Auger Bits...
2004 Dodge Sprinter 2500 Cargo Van (A61573)
2004 Dodge...
