Kubota L-47 onboard storage ideas
   / Kubota L-47 onboard storage ideas #1
hkbirdman
West Nottingham, NH
kubota L-47 TLB
Hello everyone - here are a couple of things I have done to increase storage on my new L-47. 1. - 4" PVC pipe with bottom cap for chain storage (I got this idea from another poster here on TBN). 2. ATV mesh basket for under canopy storage. ( I bought a 13" wide x 37-1/2" wide x 6-1/2" deep ATV mesh basket on Amazon-for $112.00 and mounted it using L brackets and existing bolts on rear of canopy support and heavy duty zip ties for front of basket. I then cut out a portion of front edge of basket and filed any sharp edges and and re-painted to touch up.) So far - have been very happy with my increased storage.
   / Kubota L-47 onboard storage ideas #2
I love that chain in the tubing concept. You did drill drain holes?
   / Kubota L-47 onboard storage ideas #3
Yes, did drill the drain holes.
   / Kubota L-47 onboard storage ideas #5
OK, I’m going to ask a dumb question because I’m probably missing something. It seems to me the basket is mounted flush to the underside of the roof. How do you get things in and out
I’m making a chain container today! Thx!
I cut out a section on the front side - appx. 10-12" long. If you look at the photo - where it says "Black Widow" - it is just to the left of that.
   / Kubota L-47 onboard storage ideas #7
Because fire department aluminum fiber wrapped 4000 PSI air cylinders have a "lifetime", they are drilled and discarded after a certain number of years. I attached one similar to the way HK did about 10 years ago. I cut the bottom of the cylinder off and removed the stem and mounted it upside down. Works fantastic, drains well and the aluminum does not rust.
JCT 72" Skid Steer Rotary Brush Cutter, Asset# 68 (A59076)
JCT 72" Skid Steer...
2015 JOHN DEERE 1050K WH CRAWLER DOZER (A52707)
2015 JOHN DEERE...
2017 Ford Transit 350 Passenger Van (A55973)
2017 Ford Transit...
2009 Bruton T/A Enclosed Livestock Trailer (A55973)
2009 Bruton T/A...
More info coming soon! (A55787)
More info coming...
LOT: (200 approx.) Gallons of Chevron Delo TorqForce SAE 10W Hydraulic Oil (A59076)
LOT: (200 approx.)...
