Commercial dehumidifier in crawl space
   / Commercial dehumidifier in crawl space
Try installing an HVAC system or retrofitting ductwork in a a crawlspace.
Up north, they think package units are for sitting on roofs and have no clue that a package unit can be put on the side of a house and ductwork is run UNDER the house:laughing:
When we got married in NC and looking for a home, one requirement was a basement (which is more rare than the norm here IMO).
For the last 15 years or so have been using a Aprilaire dehumidifier. The unit runs constantly in the summer, tied to the first floor system. On average, brings all three floor levels down about 5-10% in RH with the first floor generally never getting over 42% RH, which leaves me running the t-stat at around 77F in the summer.
We had duct cleaning done. They said the plastic ductwork needed replacing in the crawl space. Did that. On ours, it's not that much of a problem. Probably easier in there than going up in the attic and doing the ones there. Real challenge would be to replace the ducts in the regular basement area.
Ralph
   / Commercial dehumidifier in crawl space #12
Ralph
I've got to ask, what kind of plastic ductwork? The only product I'm familiar with is for is generally used for slabs under the house, which I most likely wouldn't touch with a 10' pole if there is a problem looking at 20 years from now. Since a crawl space is unconditioned, perhaps I'm missing the boat on something (wouldn't be the first time:laughing:).
And yes, to replace my attic LP/AC system with a dual fuel system along with lineset was a pain in the butt, it took a total of 54 man labor hours to deal with everything (3 guys including me 2 full days).
I don't know what to tell you. It seems to be pretty much standard around here. The main supplies and returns are metal, but the off takes from them are pretty much all insulated plastic.
Ralph
   / Commercial dehumidifier in crawl space #14
Wife wiped down all surfaces with bleach solution in utility room and entire encapsulation. She even removed all the floor joist insulation. (Don't need it with sealed encapsulation, e.g. not vented to outside.) Found a little bit of mold on the insulation.
The bad stuff is on the back side of the encapsulation in contact with the ground. Cannot get to it. Gotta kill it by drying it out.
No mold evident on any of the wood.
Ralph
Tell you a thing r 2 from a boy grew up in a swamp, you choose to learn or not.
Bleach is a terrible way to kill mold, vinegar is too and so is dryin de mold out.
What you got there is kind of a liner pool inside concrete walls wid a well under and maybe even around de liner.
Now I know all about de professional contractor who assured you and warrantyed and showed you pictures and sweet talked, met a few of dem myself. He probably belongs to some group and is a member of the BBB, he got money AND YOU GOT MOLD!
Any time you lay sheet of plastic on dirt any water in de dirt gonna come up to plastic and condense. You do it in Nevada desert you get water.
Job done right would have collector between dirt and de plastic. Little bit of proper digging of de dirt takes all de water to de collectors and off to a crock so it can be pumped away.
You got Mold instead, took a few years, and now you got it its der to stay.
So, how you kill it? Baking Soda, or Washing soda. Either one kills mold dead AND leaves behind a salt dat keeps a new crop from coming in quick. Nice thing is you can blow soda between de liner and de dirt real easy.
Same soda will kill moss on de roof and walls and keep it away a couple years too.
   / Commercial dehumidifier in crawl space #15
Ralph
Out of curiosity, if you ever get a chance, please post a pic:D
Still a little confused (easy on my end). I've really ever known take offs being metal on ductwork, including ductboard. Aware of plastic diffusers, but never seen a plastic take off.
   / Commercial dehumidifier in crawl space #16
The screened vents in my foundation walls provide sufficient air flow to keep the basement dry. I still don't know how the small, loud-mouth, green frogs get in the basement.
There is something between the plastic we see and the dirt, some sort of ruffled black plastic thing. Cannot get under the plastic we see unless we untape around the upper edges. Did some retaping where we enlarged the hole. Old tape doesn't hold as well. I'm not touching the tape in place.
Humidity is down to 47% now. Turned back the humidistat control on the Santa Fe.
Ralph
Posted a pic earlier that shows some of it. I'll post it again. That duct work you see to the left and goes up above the Santa Fe is the new plastic duct. It's fatter with more insulation than the old (dirty) ducting.
Ralph
We had vents under there before. Had a mud pit at times around the base of the chimney. Not nice doing any maintenance in there. Think they require encapsulation of crawl spaces in new construction, and those are usually enclosed.
Ralph
   / Commercial dehumidifier in crawl space #20
Ralph
The irony is I was going to say the only thing I really see (because I was looking at that picture as well) was the vinyl flexible duct:D I assumed (my fault) when you said take offs you were refering to the tab collars that are metal that connect to the main supply and return duct.
2008 PETERBILT 335DAY CAB (A51222)
2008 PETERBILT...
2006 FORD F750 XLT SUPER DUTY SERVICE TRUCK (A51243)
2006 FORD F750 XLT...
2003 Honda ATV (A50324)
2003 Honda ATV...
CATERPILLAR 48" QUICK ATTACH FORKS (A51242)
CATERPILLAR 48"...
Electric Forklift Pallet (A50322)
Electric Forklift...
2015 Acura MDX SUV (A50324)
2015 Acura MDX SUV...
