   / Your last generator Maintenance Run #4,371
I installed a brownout protection kit on mine, just so there no issue. Usually the problem is so someone leaving manual handle in switch and lid closed.
   / Your last generator Maintenance Run #4,372
The coils are on AC the bridge feeds the cap so that is to control the arc and surge so that contactors don't burn out.
   / Your last generator Maintenance Run #4,373
That’s not what the schematic shows. There is no capacitor, and the the transfer contacts are not in the circuit at all, they are just mechanically operated by the coils.
   / Your last generator Maintenance Run #4,375
That's what I HATE about the world today. There was a time, not long ago, that you could pick up the telephone and ask the guy that designed the circuit! You still find that once in a blue moon, and it's a light years different conversation than talking to someone at "TECH SUPPORT" who often don't have a technical or mechanical bone in their body!
   / Your last generator Maintenance Run #4,376
And that is exactly what brought me here to ask the question. Unfortunately, it still hasn’t been answered.
To summarize, the wiring to the coils is 240VAC.
The rectifier is in the coil itself, so it’s an added component, which casts doubt on it being a cost saving move. There has to be some performance reason to go to the expense.
The schematic posted above is the most current version and reflects what I see in my switch. The 12VDC transfer relay is soldered on to the board in the module rather than a separate relay as shown in the YouTube video.
I’ll continue my quest for an explanation and report back if I find one.
Thank you everyone for your contributions to the search.
   / Your last generator Maintenance Run #4,377
The youtube video had the older style load shed board. Your switch has newest version. Everything is on one board, there is no separate relay.
   / Your last generator Maintenance Run #4,378
I wouldn't be surprised if they did the rectification to eliminate the 60 cycle buzz that many solenoids on ac will get.
   / Your last generator Maintenance Run #4,379
i doubt it. it flashes for less than a second and theres a loud slam when it does. they could care less about the buzz. i guess its a mystery that will never be solved. i doubt even the techs at generac know.
   / Your last generator Maintenance Run #4,380
Yup. That’s what I said, or tried to say.
2017 MEC 1930SE 19ft Scissor Lift (A55851)
2017 MEC 1930SE...
2008 CAT 305C (A53317)
2014 Peterbilt 384 T/A Wet Kit Day Cab Truck Tractor (A54814)
2014 Peterbilt 384...
2014 INTERNATIONAL  DURASTAR 26FT BOX TRUCK (A56138)
2014 INTERNATIONAL...
1989 25'' crosley dove tail trailer (A55787)
1989 25'' crosley...
2025 GIYI GY-X39F Hydraulic Trencher Skid Steer Attachment (A53421)
2025 GIYI GY-X39F...
