3-Point Hitch Top link mount tore off back of differential case
   / Top link mount tore off back of differential case #81
If I understand this post mortem (2 pins in top link hole(s) caused a fulcrum/rotational situation) correctly, the top link on a 3pt BH is not functional like on any other attachment. There's a "stiffleg" that go's from the lower lift pins to the top link. Without this you would be unable to put the tractors weight down to the outriggers and would be relying on the BH weight ONLY to do all the digging, or it's no longer a parallel arms movement (lift arms and top link) as in a normal 3ph. You can see it in the first picture.
Check the down-force on your 3PH. Oh wait there is none and the tractor's weight is somewhat moot other than for lateral stability in X and Y planes.
Also note that 'pull' on the top link is minimal when load is close to the pins but increases dramatically if several feet back. Ever have to add front weight or load the FEL to keep front wheels on the ground with a huge mower or when using a boom pole? Somebody has and that's why IMO we don't need to prove interference or pinch points as causal.
   / Top link mount tore off back of differential case #82
I don't understand your point, is there one? Obviously there's no dp, but trying to put the bucket into even a pile of sand with a normally connected 3ph you'd pick up the BH. That stiff leg does transfer what weight is available from the tractor. There's no question that the leverage to "pull" is much greater in this situation, I just argue the "top link" (that's not a traditional top link in this arrangement) had a "pinching" condition against the lower (unused) pin at the tractor that would/could restrict the travel of this rigid top link causing a "prying" effect that assisted in this destruction. It's a hard thing to describe and maybe we just are not "getting" each other.:thumbsup:
   / Top link mount tore off back of differential case #83
Perfect. I can understand very short descriptions.:D
   / Top link mount tore off back of differential case #84
I feel for the OP. What a bad situation!
But I am wondering what the manual for the tractor states regarding attaching a backhoe to it. I know with my B2910, it requires a heavy duty top link bracket if a 3PH backhoe is attached. Been using my 3PH backhoe for 18 years without an issue, But that is just me.
No doubt that a sub frame mounted backhoe is a better setup.
Do the manuals for more recent tractors than mine, which was purchased in 2002, prohibit use of a 3PH backhoe?
Curious more than anything...
I just read through my manual quickly (covers the 3901 as well as my 3301) and didn't see a thing about backhoes. Perhaps they cover it in the book for that implement. Contrast that with the Massey warrantee; it specifically voids the warrantee if you use a 3 pth BH. The way that it's written, if I used my BH once and lost the engine a year later, they could refuse to pay if they wanted to be that way.
That was a deal breaker when I was tractor shopping 2 years ago.
I worry more about breaking it when transporting than when I am actually digging, as I run at idle and don't pull very hard with it. I have been intending to get a subframe but as I mentioned before my BH750 is too old to get a custom frame, so it will have to be modified to fit.
Reading this thread makes me think I need to move it farther up the list; as in, before I use the hoe next time.
I think the "crowd sharing" is more of a young people thing... you give me five dollars today, and tomorrow I give it back to you for something else.
Most TBN members put that five in the bank, along with many more over time, in case they ever need it.
As for digging; my first BH would indeed ride up and down on the 3 pth arms. I actually did a lot of work with it, digging stumps and planting trees. I even dug a 5 foot deep hole and set a utility pole for a friend of mine.
It was a CadPlan kit which I bought premade... a school teacher downstate at Windham High used to buy the kit, weld them up, and sell them for 3K. It had about 10% less pulling power than my woods 750, but would very easily pull itself apart if I wasn't careful. I learned to scratch with it, not push; otherwise it could have driven me right up into the roll bar.
   / Top link mount tore off back of differential case #85
It's indeed hard to describe. The second pin on the top link mount, doesn't make any difference. That top link doesn't move up and down enough to hit that pin.
What I was trying to explain, is that, even though the top link is rigid and has that triangulation that prevents the 3 pt to simply lift, there is still the possibility of tilting the backhoe left/right (looking from the back of the tractor).
Since the provided top link doesn't have a ball joint (like a traditional top link) and it also fits tight in the top link mount, if the operator would accidentally push one stabilizer too far before the other one, it could twist that top link mount right off.
Or just by driving over a bump with one of the rear wheels, could possibly be hard enough to twist that top link mount too.
I hope it's somewhat understandable.
   / Top link mount tore off back of differential case #86
MY Massey Ferguson manual that covers the 1705 and 1710 (factory backhoe equipped) and the 1715 and the 1720 (factory backhoe equipped) states as graphic below...
   / Top link mount tore off back of differential case #87
re putting a 3-point BH in front of a skid-steer - Seems to me you would have to get out of the skid steer seat and climb up on the BH seat every time you moved. Same as I have to with the hoe on my tractor, because it wasn't designed for a tip-back seat or other dimensions to run the hoe without getting off the tractor seat and walking back there. My use digging out stumps doesn't need many dismount/move/remounts, but for trenching its a PIA. In summary, a tractor or skid-steer designed in the first place to mount a hoe and operate it from the driver's seat will be a lot more productive than a mismatched combination.
   / Top link mount tore off back of differential case #88
Guys what I was getting at and in both digging and traveling positions is that the stabs are two points to lift the BH or the tractor once the 3PH is topped out bc it has no down force and will be. (points of stress from that? why not?)
That makes two points of contact with the ground. So if the FEL becomes the third point of support forces are on the 3PH in whatever direction they're exerted and between the three 'legs'. Otherwise we'd dig with front tires on the ground. I still contend that when traveling there's a lot of weight behind the pins and that puts uncommon tensile load on the top link while compressive on the draft arms.
IIRC that's why there are sub-frames and why they shouldn't connect to the top link. And any of us who dig much know forces come in all directions, intended or not. Doesn't have to be just one thing causing this, likely most all that have been suggested. Cracks could have begun from one thing or another and we tend to overthink the moment of disaster as being just one little detail that finally caused it.
btw, Kind of a shame we're not young enough to help a guy out by pitching in.
   / Top link mount tore off back of differential case #89
Looking at this modern gear I feel like Rip Van Winkle. My 1979 Kubota BH doesn't have that triangular stiffener. The BH's weight alone is all there is for digging. I raise the 3-point to drive around. For digging, lower the outriggers to let the hoe rest on the ground then drop the 3-point lever so it can't try to lift the hoe as the outriggers work down into the ground. Definitely Old School but this design is likely why I haven't broken anything in 15 years using a 3-point BH on a 24 hp tractor. Sure beats a shovel and wheelbarrow!
I think that comment that the custom (?) upper link doesn't allow any side to side slack, is important. Just swiveling the hoe to the side to dump the bucket loads side stress there. Doing this on a minor side slope would be worse. I wonder if that top link was original from Woods. It seems to me it should have a ball joint at the tractor end to prevent this stress.
   / Top link mount tore off back of differential case #90
FWIW, I just checked my Owner's Manual for my L4330 "Implement Limitations, page 12:
Backhoes:
Max digging depth, 90 inches.
Max weight: 990 lbs
Subframe: Necessary
This OM covers models L3130, L3430, L3830, L4330, L4630 and L5030.
By saying "subframe necessary", I'm guessing that that precludes the use of a 3ph backhoe.
   / Top link mount tore off back of differential case #91
You keep pulling on those thin castings, and sooner or later, something is going to give!
That's the point I was trying to make earlier. Nothing, including the top link should be attached to the transmission casing. Everything should be supported by the frame somehow. WoodMaxx and whoever else makes these should be providing additional bracing kits if necessary.
   / Top link mount tore off back of differential case #92
So whats the cost on fixing this, 1k for trans case and 2k for labor, the biggest concern for most tractor owners is finding the right dealer/person to do the fix.
And for those concerned with a back-hoe on their compact Kubota's, it dont take a back-hoe to break the trans hosing on kubota, a pto winch broke mine but mine was fixable well sort of, least I was able to get it usable again by a very helpful tip on TBN. It was a forgotten Kubota secret accessory that should be put on every compact Kubota that does any kind hard pulling work. I welded the crack best I could but I dont trust cast welding alone, and that top link needs to be on something more solid then that thin trans housing anyways. I had mine apart and those Kubota trans casting are to thin for yanking on IMO, it's approx 5/16" at best, the top link shouldn't be on the trans housing by itself.
   / Top link mount tore off back of differential case #93
I didn't mean torsional load when looking from the back, I meant torsional when looking at the top link bracket from the side.
I cant tell if the BH top link will contact the lower unused pin, but it looks like it could.
If setup properly it shouldn't be able to lower enough to bind on that pin, but we don't know if it was setup properly or not.
If the BH/tractor was well used and beat up I would say fatigue, but looking at the condition of both I dont think that's the case.
The top pin/s binding would introduce a very high load localized to the top link bracket in a way it wasn't designed to handle.
   / Top link mount tore off back of differential case #94
I thought we covered this, but maybe not.
The toplink never moves up and down. It can't because of the triangular design of the Woods mount.
When you push the backhoe bucket into the hard ground the top link pushes toward the tractor.
When you lift the backhoe bucket the top link pulls away from the tractor.
This is no different than any other 3pt attachment.
But it's ability to exert greater push/pull forces is.
Its not supposed to, but if this was just mounted it could have been set down on that pin and then the triangulated links set.
If this had appeared to have been a previously used setup it would be less likely.
Since it looks like it happened before being used I'm thinking it might be a setup issue, not a usage issue.
   / Top link mount tore off back of differential case #95
... This is no different than any other 3pt attachment. But it's ability to exert greater push/pull forces is.
Richard, this time you said it best. :)
   / Top link mount tore off back of differential case #96
Backhoes:
Max weight: 990 lbs
Subframe: Necessary
As I stated previously, I have the same manual as the OP. I don't see any mention whatsoever of backhoes. The only place I see it mentioned is in a generic safety pamphlet which comes with all Kubotas.
I also read the warranty, and didn't see it mentioned there either.
   / Top link mount tore off back of differential case #97
In the operators manual they list the subframe as "necessary " under the backhoe in implement limitations. Don't remember seeing anything specific to 3pt mounted.
   / Top link mount tore off back of differential case #98
I finally found what you are referring to. Maximum depth; 90 inches. Maximum weight; 926 lbs.
Subframe Necessary. I suddenly hear an echo. :D
   / Top link mount tore off back of differential case #99
They definitely don't highlight it though!
   / Top link mount tore off back of differential case #100
I did, because it took me so long to find what everyone was telling me is there.
2017 GENIE S-45 TELESCOPIC BOOM LIFT (A60429)
2017 GENIE S-45...
2008 FORD F-550XL SUPER DUTY INSULATED BUCKET TRUCK (A60430)
2008 FORD F-550XL...
2022 FREIGHTLINER M2 BOX TRUCK (A59905)
2022 FREIGHTLINER...
2002 TOYOTA 7FDKU40 FORKLIFT (A57880)
2002 TOYOTA...
2017 PJ TRAILER 20' T/A TRAILER (A58214)
2017 PJ TRAILER...
2025 Stump/ Trench Bucket Mini Skid Steer Attachment (A56857)
2025 Stump/ Trench...
