Need to remove tapered tie rod end on Kubota M7040
   / Need to remove tapered tie rod end on Kubota M7040 #12
One big whack with a big sod off hammer, with a bigger one behind will do more good than loads of little taps.
   / Need to remove tapered tie rod end on Kubota M7040 #13
For sure, the OTC tool is good. Only doing a once in a while job, couple of hammers properly used will do the trick. Working in a dealership for years, flat rate of course, sometimes it took more time to find the tool than just give the knuckle a thump with a hammer. Other times, space restrictions made the tool necessary.
Just in case I do tear the tie rod rubber boot, a new one is over $40. I guarantee it won't rip on my watch.
   / Need to remove tapered tie rod end on Kubota M7040 #18
What?... Universal parts don't fit your tractor?
Dale
that would be odd.:shocked: remember, tractor makers, as well as most other manufacturers buy common stock parts, rather than having to manufacture all the parts themselves, it saves them money, and time, and factory space!..
   / Need to remove tapered tie rod end on Kubota M7040 #19
I'll keep that in mind when I need parts for my E-350 MB.
I'm the OP and the job is all done and all finished. I had a mechanic friend come out and pound on the casting but nothing happened. I sort-of stopped him because that casting the tie rod went into looked line a million dollar part and I wasn't going to break that. It's easy to say whack it as hard as you can with a sledge hammer but it's quite another when it's your own part.
The tie rod came out with a truck sized pickle fork and I did tear the rubber boot. Dang it and $43 but that's life. Tractor now handles much better and life is good again.
2018 CATERPILLAR 299D2 XHP SKID STEER (A52709)
2018 CATERPILLAR...
2007 FORD F-150 XL TRITON (A58214)
2007 FORD F-150 XL...
10 - 3/16in Plate Steel Sheets (A55973)
10 - 3/16in Plate...
2015 Freightliner Derrick Digger Truck (A55973)
2015 Freightliner...
66'' SKID STEER BUCKET (A56857)
66'' SKID STEER...
2019 Ford F-150 4x4 Crew Cab Pickup Truck (A55973)
2019 Ford F-150...
