3 cylinder vs 4 cylinder debate
   / 3 cylinder vs 4 cylinder debate #1
BrokeFarmerJohn
Columbus Ohio
2017 Mahindra 5555, John Blue G-1000, Massey Ferguson 98, John Deere GP
So I have been doing research on 3 cylinder vs 4 cylinder Diesel engines.
Has anyone actually tested if a 3 cylinder is more fuel efficient? Or tested which one is smoother, quieter etc?
For example I have a Mahindra 5555 with a 2.7L 3 cylinder engine (55hp) I believe it’s same engine in 5570 (70hp). A friend has a LS 6168 with a 2.5L 4 cylinder engine (68hp).
It got me thinking which one was best. Not a tractor to tractor comparison but 3 cylinder to 4 cylinder comparison.
Note* (fun fact) my 3 cylinder rated 540 PTO RPM is 2059 engine RPM while the LS is 2500 engine RPM.
I have browsed and read a lot on this subject from multiple forums but most info seems to be opinion not factual testing.
   / 3 cylinder vs 4 cylinder debate #2
Whether a machine (not just a tractor) has 3 or 4 cylinder engine is not a criteria I would consider for basing a purchase decision. Durability, reputation and performance of specific engines would be. Few if any measurable engine attributes are predetermined by counting the number of cylinders.
   / 3 cylinder vs 4 cylinder debate #3
I've never had a 3 cyd. Both of mine have been 4. And you need to throw turbo vs naturally aspirated in the discussion. Both of mine were turbos. As far as PTO. My tractor has switchable 540 to 540E (Economy) PTO. On my tractor standard PTO is 2400 engine RPM and economy is 1715 engine RPM. My old 5310 was exactly the same. I honestly would never own another tractor without economy PTO.
My 05 JD 4320 was turbo 4 cylinder. The Mahindra and LS are both turbo charged.
I haven’t had ECO 540. It’s not as big of a deal for me because I don’t do much PTO work. Mostly loader work.
   / 3 cylinder vs 4 cylinder debate #5
I primarily was interested in it on my 5310 to run my PTO generator for extended hours. After I got it and used it, it is probably the single best feature on a tractor for me. Aside from the cab, which is the reason I traded up to the 5090.
   / 3 cylinder vs 4 cylinder debate #6
Both of my tractors were 3 cylinders, a Kubota 900cc’s, and a JD 1250cc’s (more or less) made by Yanmar. The Yanmar is smoother but idles at 1500 rpms, I think because it is smoother at such a high idle. The Kubota was rougher, at idle very rough, at about 1100 rpms and I would sometimes throttle up a little to smooth it out.
The Kubota was noticeably more fuel efficient and was rated at 23 hp. The Yanmar is rated at 25 hp and I expected it to feel stronger thinking it was derated to make it no more than 25 hp but it feels like 2 more hp than the Kubota. Both seem to be very solid engines.
   / 3 cylinder vs 4 cylinder debate #7
If you want smooth step up to an in-line six.
   / 3 cylinder vs 4 cylinder debate #8
Yes, the little Waukashaw 6 cylinder in my Oliver 1550 was a very smooth and sweet sounding engine.
A little 232 cu. in. diesel making 50HP at 2200 rpm, they sounded and ran smooth, but when the loads got high and started pulling that engine down she wouldn't stay and lug but required a down shift and revs to keep going.
What I have noticed is that for comparable displacement engines with similar hp ratings the torque curve of the lesser number of cylinders seems to be flatter and start sooner;
ie.. a 3 cylinder seems to make its torque sooner then a 4 cylinder and have a bit better lugging power, the same when comparing a 4 cylinder to a 6 cylinder the torque curve seems to usually start lower and be flatter the fewer the cylinders, the more cylinders the smoother they seem to run.
   / 3 cylinder vs 4 cylinder debate #9
Some 4 cyl engines have balancer shafts that 3 cyl don't require.
   / 3 cylinder vs 4 cylinder debate #10
the more cylinders an engine has, the less horsepower each one has to make, so more cylinders should mean longer longevity..
UNUSED PAIR OF MINI RUBBER TRACKS (A52706)
UNUSED PAIR OF...
8065 (A55852)
8065 (A55852)
2016 FREIGHTLINER CASCADIA TANDEM AXLE SLEEPER (A58017)
2016 FREIGHTLINER...
New/Unused SD Lanch SDLE20 Mini Excavator (A57453)
New/Unused SD...
Wagon Wheel Rocking Chairs (A55758)
Wagon Wheel...
Mini John Deere Truck (A55853)
Mini John Deere...
