Tractors and wood! Show your pics
   / Tractors and wood! Show your pics #15,281
Who was it that made that nice bridge in the forest earlier this summer, Old Path, I think? I believe you asked to see pics of my own bridge plans also. Well I finally got around to getting started on mine recently. I'll use this bridge to get my tractor across my creek and be able to snag firewood from any deadfalls on the other side, and expand my trail network. Decking will be doubled-up treated 2x6s that were reclaimed from a big deck that was in fine shape; hope to get those on next weekend. Comments and suggestions welcome, though it ain't changing now, haha. My 7-year old Son has been learning a lot and become quite a useful helper.
The only concern I have is, is the bridge going to be wide enough, looks about 7', I'd want 9' minimum. The cinder block footings and telephone poles is a good way to go as long as the power company wont miss the poles. How come you have water in that brook, my brook has been bone dry for over a month, so dry the frogs don know where to go, it's great having a 7 year old gopher to help.......
   / Tractors and wood! Show your pics #15,282
That's a pretty nice bridge footing Deezler. How much span do you have there ? Looks like your fall foliage has barely started. Ours is almost over - very short lived this year.
gg
   / Tractors and wood! Show your pics #15,284
I took the day off and worked between the rain drops, more like helped out. We got the first carrying beam glued screwed and bolted together, then we lifted it in position, wheres feather hydraulics when I need them.... Now the 100 dollar question will it stay up over winter......
   / Tractors and wood! Show your pics #15,285
/QUOTE]
Maybe put a removable jack under that joint when the snow load starts to build up then remove it in the spring. Or do you want to do an acid test and see if she holds ?
gg
   / Tractors and wood! Show your pics #15,286
Maybe he only takes them when he needs them, and puts them back before they notice the poles are missing?
   / Tractors and wood! Show your pics #15,287
Nice... Interesting scarf joint. What glue did you use?
   / Tractors and wood! Show your pics #15,288
gg
I mention that to my son but he said that he already shovels the other roof after big snow, well he does need the exercise cause he dont saw shingles in winter...
   / Tractors and wood! Show your pics #15,289
Is that a rock the beam is setting on? At the risk of being redundant... why does he do all of that work, yet have such scary footings?
   / Tractors and wood! Show your pics #15,290
He used Elmers wood glue, some lag screws with two 5/8 threaded rods, he said next beam the splice will be at other end. I was going to invent away to saw 24' on a 20' mill but it would require to much redneck engineering, not to mention a 24' log that will saw out a 6"x10", thats a big log that also requires lot more work, and then I might only have a couple trees left that size, but if this falls down..........
UNUSED JCT SKID STEER QUCK ATTACH 72" BRUSH CUTTER (A51244)
UNUSED JCT SKID...
Wolverine Skid Steer Drum Mulcher (A50515)
Wolverine Skid...
2010 Toyota Tundra (A50323)
2010 Toyota Tundra...
UNUSED FUTURE MINI EXCAVATOR HYD THUMB (A51244)
UNUSED FUTURE MINI...
Massey Ferguson 65 Loader Tractor (A50514)
Massey Ferguson 65...
2021 TAKEUCHI TL8R2 SKID STEER (A51242)
2021 TAKEUCHI...
