My Front Gate Project
/ My Front Gate Project #1
EddieWalker
Epic Contributor
Tyler, Texas
Several, all used and abused.
About 15 years ago I cleared the trees, moved a bunch of dirt and created my entrance. I built the columns and installed the white vinyl three rail fence. Over the years I've sort of lost interest in the white vinyl fence to the point that I'm going to remove it and go with wood. But that's not part of this project, right now.
I've been on and off about putting in a fancy entrance gate, or doing nothing and just living with the gates on the posts that flop around that we rarely close.
My wife really wants the gate closed every night, but we are too lazy to actually get out of our cars and close it every night.
I've decided to build two more columns like what I already have and then mount a 14 foot wire filled farm gate to it and paint it black. Cheap and quick, but not the fancy gate I've always wanted. I can always do the fancy gate in the future, but after 15 years of not getting around to it, I'm not sure if I ever will.
Step one was building the forms and getting them into position. They are 18 feet apart from where the gate hinges will be. On one side will be the 14 foot gate, and on the other end will be a 4 foot walk through gate.
I'm off to Lowes to get some concrete, and I'll have that done before the storms hit tonight.
/ My Front Gate Project #2
So what is the plans for the space between the existing fence and the new columns?
/ My Front Gate Project #3
What is wrong with the vinyl fence?
I cringe every time I see someone put up a white wooden fence. Been staring at a broken down one for 20 plus years that should have been torn down 3 paintings ago. They just finally tore it down last week. They are pretty for a year at most then they go down hill.
/ My Front Gate Project #4
My vinyl fence is nearly 20 years old and still looks great. Have to pressure wash every so often, but sure beats wood fences. I hate wood fences. Come on, with those nice brick columns...make a nice steel gate. 7674A1C1-CA6A-4647-A0FE-A641C401A5D2.jpeg
My secondary reason for wanting the gate is in case one of the dogs gets out. They are chipped, but that doesn't mean they wont get run over if they ran out the gate and onto the road. Which is another thing that's wrong with the vinyl fence, it doesn't keep anything in or out. Horses push it over, goats and dogs climb right through it.
I'll set a treated 6x6 post between the columns and attach goat panels to the posts, and then run treated 2x6's between the columns. Eventually, I plan to do the same with the vinyl fence, but with rolled goat fencing instead of welded panels.
I poured the concrete by mixing it with my Spade Drill in a bucket. I lost count how many sacks I used. I was going to buy6 for each post, then figured I should be save and get 10 for each one. I have some left over and I need to unload them before the storm hits tonight, but I'm having lunch and I don't really want to deal with them right now.
I can't remember why I bought the steel 2x4 tubing. It's super thick and strong, and just laying around, so I cut holes in it with my torch and welded on some nuts for the gate hinges. The blocks will go next to it and the threaded rod will go into the block where I will lock it into place by filling the open area with concrete.
My vinyl fence is nearly 20 years old and still looks great. Have to pressure wash every so often, but sure beats wood fences. I hate wood fences. Come on, with those nice brick columns...make a nice steel gate. View attachment 671076
Your gate is really nice!!!! That's what I want for my place. I just haven't decided what exactly I want it to look like. I've drawn a dozen designs and like them all for a little while, then I stop liking that design and eventually come up with another, that I eventually stop liking. I told my wife that when it's right, I'll know and it will happen.
/ My Front Gate Project #7
You are a contractor, and don't have at least a small 120v concrete mixer, and a generator to run it anywhere?
/ My Front Gate Project #8
I’ll have to admit to being a contractor without a cement mixer. I’ve been looking to buy one but haven’t found any good candidates. My block guy is pretty good about letting me use his.
/ My Front Gate Project #9
Get bill gates to make you a huge computer screen gate. Then you can keep changing the design. But seriously, goats and vinyl are not a good idea, unless you add a field fence inside it with zip ties like our neighbor did. Our horses never have done anything to the vinyl fence.. i guess its cause i never have anything on the other side for them to eat.
/ My Front Gate Project #10
I used to have a tow behind mixer for pouring 8 sac of ready crete for my generator pads....sold it, went back to wheelbarrow. It took longer to clean mixer than to mix with wheelbarrow.
/ My Front Gate Project #11
How big of a pad did you pour? I usually pour HVAC pads 5x5. Even a 3x5 4” thick would need more than 8 bags. I did a footer for a porch last week that took like 80 60 pound bags. I was gonna just call a truck. 1.2 yards at $130 a yard plus $100 delivery wasn’t a lot more than mixing it and a lot less work but they wouldn’t bring it. There’s too many big jobs to attend to.
/ My Front Gate Project #12
I have poured literally 100s of them. Mine are only 28” x 54” x 3.5” pads. Never more than 8 sacks of 60# concrete.
/ My Front Gate Project #13
I like for the pads to touch the house. It’s just a weedy mess behind them if they don’t.
/ My Front Gate Project #14
I had to pour some cassions and a step retaining wall for my front porch a few years back and i ended up buying 90 of the 90# bags and had to go rent a commercial gas mixer. I called the concrete company also, and due to the minimum load service charge, i did it myself for probably 1/5th cost. It truly went real fast with the large mixer. That was the only time i missed my old mixer. But it actually didnt cost too terribly much to rent one.
/ My Front Gate Project #15
I like using mortar mixers better. They’ll mix about 600 pounds at a time which is a lot more than a little cement mixer and they’re a lot easier to load with the grate at the top. The bag cement only had like 1/2” gravel and they’ll handle that fine.
Yes, I have a small concrete mixer. I chose not to use it for such a small project. Takes longer to clean it out then to mix 13 sixty pound sacks in a bucket. I also wont bother to use it for mixing the mortar when I do the 28 blocks next weekend.
I don't need a generator, I have power to the columns already. I'll pull from them to power the gate opener, and the two lights that I put on top of the columns to match the lights that are already on the original columns.
/ My Front Gate Project #17
Eddie, one possible problem I see is using a gate opener when one leaf is a walk gate, that one usually has a latch like an entry set that engages the stationary link. Something to ponder on, since most double electric openers use a master-slave sequence so they can open/close without interfering with each other.
Another thing that I think that everyone with a driveway gate should consider is one of those solar HF rope lights. Give it a little bit of visibility during bad weather; I can't count the number of pranged gates that would come in on a trailer, one of the sales weasels would come down and say it needed fixed because it got backed into by someone turning around during a storm, or just not paying attention. For $8 on a coupon it's cheap insurance.
/ My Front Gate Project #18
To me, vinyl fences look to sterile to me. They may be OK in a new subdivision, but seem to really stand out on a nice wooded acerage. Plus when the snow plows go by throwing snow, they are easily damaged especially on dirt /gravel roads. Just my opinion. Jon
/ My Front Gate Project #19
In 20 years ive only had to replace about 4-6 rails. All damaged by me or wife on mower. Too far away from road to worry about plow.
And i personally love the look of 3 rail vinyl fences. To each their own
/ My Front Gate Project #20
I値l have to admit to being a contractor without a cement mixer. I致e been looking to buy one but haven稚 found any good candidates. My block guy is pretty good about letting me use his.
I've never been a contractor, and have had four different mixers in my lifetime.
Still do have a small old one that works just fine, but I don't use it anymore.
Won't sell it though.......just in case I should need it sometime.
At a very few weeks short of 80, I have WAY too much stuff that fits into the "just in case I should need it sometime" category.
2020 Chevrolet Tahoe (A68183)
2020 Chevrolet...
MILLER BOBCAT 250 PORTABLE ARC WELDER (A64276)
MILLER BOBCAT 250...
RIDGID AIR COMPRESSOR (A67714)
RIDGID AIR...
PORTAPOTTY (A68842)
PORTAPOTTY (A68842)
2019 PETERBILT 567 (A67714)
2019 PETERBILT 567...
213138 (A64276)
213138 (A64276)
