Light bar
/ Light bar #21
Would these lights be ok to use or is it to much voltage?
/ Light bar #23
I was going to put 4 of them on my ROPS. So that would be like 500watts with 4 of them I guess.
/ Light bar #25
I was going to put 4 of them on my ROPS. So that would be like 500watts with 4 of them I guess is that to much???
You may want to jump over to the Kioti forum and get some advice on safe amps to pull.
/ Light bar #30
What have people used for switches anyone have any factory looking switches that put in the spare area of the dash?
/ Light bar #31
/ Light bar #32
I have something like that I got on Amazon. Those lights are so misinformed. There is no way that led light is going to use that many watts. That is probably for the whole box. There has got to be a misprint somewhere. Maybe like 1.26 watts each. I mean my lights Look like that and I put 3 on my tractor and tied in with other lighting and have not blown a fuse yet. Talked to my electrical guy I work with and he is a professor that teaches this stuff. Let痴 just say if they used that much current the included wiring would be a much heavier gauge.
/ Light bar #33
Subscribed so I can find this later.
Debating setting up a couple lights off a cigarette plug or wiring a dedicated fuse block and switch.
I know what I want to do, but I also know how many projects ice got before snow flies....
/ Light bar #35
Hey guys so at the back of tractor I found this wire harness wondering is this like a power source I can tie my LEDs into or? IMG_4431.JPG
/ Light bar #36
Hey guys so at the back of tractor I found this wire harness wondering is this like a power source I can tie my LEDs into or? View attachment 674934
It probably is and could well be already 'hard wired' to your Light-Selector switch, which means that the circuit is fused... I know that this is the case with my 4105 and I connected a, ROPS mounted, 6-lamp LED light bar to my connection.
A volt meter will confirm when the Light-Selector switch is turned to the correct position.
/ Light bar #37
I don't think it is a power point. It has a jumper connector shorting the two wires. Probably a seat safety switch connector for a model which uses a seat with pressure switch.
/ Light bar #38
Hey guys so just wondering if anyone knows if kioti has a factory 2 way switch that I can put in this blank spot for my lights? I want it to look clean so was hoping to have a switch that fit right in this blank spot with out having to cut anything. IMG_4433.JPG
2022 EZ-GO ELITE...
New/Unused Landhonor Hand Chain Hoist (A65583)
New/Unused...
2020 VOLVO EC200EL EXCAVATOR (A65053)
2020 VOLVO EC200EL...
2005 MACK CHN613 (A65643)
2005 MACK CHN613...
2015 DODGE MINI VAN (A63290)
2015 DODGE MINI...
2018 CHEVROLET SILVERADO 2500HD (A65643)
2018 CHEVROLET...
